Thread: Help Identifying noise
Results 11 to 20 of 30
  1. Re: Help Identifying noise
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Shocker bushes, are they visible?
  2. Re: Help Identifying noise
    Dec 2011
    East Grinstead
    Quote Originally Posted by fourringsrus View Post
    You say the car has been dry stored for 8 years, does that mean parked up/ unused for 8 years or just that it has always been a garaged car.
    If unused then a lot of bushes could be dried out or perished but not necessarily showing failure.
    Yes, sorry that was ambiguous. Always garaged. In regular use.
  3. Re: Help Identifying noise
    Dec 2011
    East Grinstead
    Update:
    I had the suspension strut out and the top mount is fine, no cracks or pershing. I'm running out of things it might be. It's also getting worse which helps a little! It now makes the noise over rough road surfaces as well.
    I noticed that after it had been up on axle stands and then dropped back to the floor it takes two or three accelerating/braking cycles for the noise to come back.
    To me this points to the suspension struts themselves. I have ordered a set on the basis that it's on the original dampers and at 90,000 miles they must be pretty worn.
    My wheel alignment was so far out of whack from all the messing about that the ESP light came on (I read that it has a sensor for the wheels pointing in the wrong directions LOL) I redid the alignment by eye and it's now OK. Obviously I'll have it redone by the garage after I'm done changing things.
    Has anyone used one of the cheap alignment kits from ebay
    Trackace Laser Wheel Alignment Tracker / Tracking Toe Gauge | eBay
    and are they any good?
    I'd only have to use it twice for it to pay for itself.
  4. Re: Help Identifying noise
    Mar 2016
    Minervois, France
    53 Post(s)
    Just a wild suggestion.
    Is it possible that something which has been replaced has not been tightened up correctly? e.g. some linkages etc. should only be tightened with the wheels on the ground with the normal load in the car.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  5. Re: Help Identifying noise
    Dec 2011
    East Grinstead
    Quote Originally Posted by FrenchAudi View Post
    Thanks for the suggestion, wild or otherwise!
    The lower control arms and link were all replaced by me 4 years ago (with a jack under the hub to lift the car to normal load) and that's the last time they were touched until just the other day when I torqued them all up to see if they were OK (they were all fine)
    Upper control arms were replaced by me a few weeks ago and the ball joint ends have been disconnected and reconnected countless times since then in my search for the problem! It's only the rubber bushing end of those that needs tightening under vehicle load (or measured distance from the top of the strut) which I did.
    I have re-torqued the sub-frame mounts and gearbox mounts.
  6. Re: Help Identifying noise
    Mar 2016
    Minervois, France
    53 Post(s)
    Have you checked the brake caliper mounting and pads on that side, also if anything stuck in the brake mechanics? How about the female splines in the hub?
  7. Re: Help Identifying noise
    #17
    Dec 2011
    East Grinstead
    Yes to the brake pads and mounting. All been out cleaned and reinstalled. Caliper bolts are tight and pad retaining bolts and spring all good.
    Female splines in the hub I have not checked specifically but I didn't notice any free play when I reassembled them and they were all cleaned and reassembled with Loctite 641 Bearing Fit Retainer just the other day which if they were were worn I would expect to silence or at least improve things if only for a short time
  8. Re: Help Identifying noise
    #18
    Mar 2016
    Minervois, France
    53 Post(s)
    I suggest you get it over a longish pit, where you can drive back and forth to duplicate the noise while someone looks/listens from below.
  9. Re: Help Identifying noise
    #19
    Dec 2011
    East Grinstead
    It's booked into the garage for Sat unless the new struts solve the problem!
    I think anyone would be doing pretty well to see what the problem is as someone drove over their head though
  10. Re: Help Identifying noise
    #20
    Mar 2016
    Minervois, France
    53 Post(s)
    I rather hope they'd have enough sense to keep their head down and I meant drive slooowly
  1. Question Identifying where the issue is
    By cxite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2015, 09:50 PM
  2. Help identifying gearbox oil,please...
    By AN AUDI FAN in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-04-2015, 07:52 AM
  3. help identifying car.
    By Ben in forum Chat - Anything with wheels
    Last Post: 24-09-2011, 02:19 PM
  4. Turbo identifying
    By richard3009 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2009, 12:50 PM
  5. Please Help Help with identifying part
    By devereux in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 10:33 PM
