Dear All
Sorry I am new to this forum
can anybody help and give a right steer? I did the scan on last Saturday because the car gearstick was stuck in P and all the letters “PRNDS” were flashing so here is the scan
Saturday,05,May,2018,16:42:22:35442
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ4F78N061924 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53
56 61 62 6D 72 76 77
VIN: WAUZZZ4F78N061924 Mileage: 186330km-115780miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
0E-Media P
layer 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-BPP.clb
Part No SW: 4F5 910 401 Q HW: 4F0 907 401 C
Component: 2.7L V6TDI G000CG 0010
Revision: --H05--- Serial number:
Coding: 0011382
Shop #: WSC 02334 758 00200
VCID: 2F6D37E7BE973E3CB1-807A
2 Faults Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 163981 km
Time Indication: 0
Date: 2017.01.17
Time: 06:47:03
Freeze Frame:
RPM: 1071 /min
Torque: 101.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.9 %
Temperature: 7.2°C
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 10:20:47
Freeze Frame:
RPM: 1197 /min
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.45 V
Bin. Bits: 00101010
Torque: 249.6 Nm
Bin. Bits: 00000100
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F5 910 155 R HW: 01J 927 156 JG
Component: V30 0AN 2.7lTDI RdW 0010
Revision: --H03--- Serial number: 00000000000527
Coding: 0000001
Shop #: WSC 02325 758 00200
VCID: 3663028341CD0FF4F2-8062
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 65C195CFACEBB46C8B-8030
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 12
Reset counter: 138
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 11:38:12
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x01A8
Hex Value: 0x00FF
01119 - Gear Recognition Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 149
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 11:46:31
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0031
Hex Value: 0x01AB
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500900039
Coding: 0000019
Shop #: WSC 02323 758 00200
VCID: 63C58BD7A2DFCA5C65-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350JP077826041
Coding: 0030002
Shop #: WSC 00000 000 08192
VCID: 2541D5CFEC6B746C4B-8070
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000789103
Subsystem 3 - Serial number: 0121.06.070000000100010447˙
Subsystem 4 - Serial number: 010447˙
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030290807
Coding: 0001046
VCID: 1C37F02BDF21B5A4E4-8048
2 Faults Found:
00657 - Positioning Motor for Central Vents (V102)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 26
Reset counter: 112
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 11:37:56
Freeze Frame:
Voltage: 11.30 V
Temperature: 16.0°C
(no units): 31.0
(no units): 64.0
Temperature: 16.0°C
00256 - A/C Pressure/Temperature Sensor (G395)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 11:38:00
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0010101
Shop #: WSC 02335 758 00200
VCID: 326B3E93ADA513D4DE-8066
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046006 Serial number: AUZ5ZBG3489423
Shop #: WSC 00000 000 00000
VCID: 1A3BF633D515CB94F6-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0UA929
Coding: 0013381
VCID: 2959D9FF8073500C6F-807C
Subsystem 1 - Serial number: 6332CSME2A71182F7
Subsystem 2 - Serial number: 6342CSME2973655FE
Subsystem 3 - Serial number: 6352QSME3C4C3839V
Subsystem 4 - Serial number: 6362QSME3F500F17O
Subsystem 5 - Serial number: 63734SME3A593121Z
Subsystem 6 - Serial number: 63834SME3C46401D2
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055072640024
Coding: 0102141
VCID: 275DDFC79667667C79-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 982 T
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 72W553U97
Coding: 2304458
Shop #: WSC 00011 888 96745
VCID: 2345CBD7E25F8A5C25-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07926818D
Coding: F551BE57303A0600
VCID: 2D512DEFB49B4C2C83-8078
2 Faults Found:
00317 - Rear Lid Control Module (J605)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 11:37:58
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H50 1060
Revision: 00000000 Serial number: 364JQ077721331
Shop #: WSC 00016 210 69841
VCID: 3B7513B77AEFD29C0D-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: ES
Coding: 0002682
Shop #: WSC 02327 758 00200
VCID: 2C5720EB8F81452494-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01070243500000
Coding: 0010491
VCID: 3169319FA8A328CCA7-8064
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1200000
Coding: 030000
Shop #: WSC 02399 823 56573
VCID: 285FDCFB5B79690470-807C
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000481665
Coding: 0001103
VCID: 5EB3BA2389BDE7B44A-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: g
Coding: 0002810
2 Faults Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 31
Reset counter: 113
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 11:37:56
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 29
Reset counter: 153
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 15:12:55
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000531
Shop #: WSC 02324 758 00200
VCID: 204FC4DBF349914438-8074
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394J1077818285
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000150681
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 0709290939
Coding: 344630393135313035442056413030373039323930393339
Shop #: WSC 00000 512 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 255
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 12:54:03
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 12:57:13
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 12:57:24
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 12:58:13
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 185728 km
Time Indication: 0
Date: 2018.04.27
Time: 12:58:22
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0002090
VCID: 2E532AE3B99D3734BA-807A
Address 6D: Trunk Elect.
Cannot be reached
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0002090
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06240726803976
Coding: 0201006
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 D HW: 4F1 862 335
Component: BTA H09 1120
Revision: 00H09000 Serial number: 00000007517735
Coding: 1040021
End-------------------------(Elapsed Time: 03:14)--------------------------
I have a VCDS cable and clear the code from then it is fine but I have read on the forum the fault will come back
Can anybody advise me what do I need to do?
Any help will be much appreciated
Many thanks
WAWA6
