Thread: Help with 6n Polo Window Regulator/Motor Please
  1. Question Help with 6n Polo Window Regulator/Motor Please
    Sep 2007
    Sleaford, Lincolnshire
    Hi all,
    Bit of a problem I hope someone can help me with? My passenger side window regulator gave way a couple of weeks ago, dropping the window with a loud thud (I honestly don't know how it didn't smash!). Took a look, saw it was the clips, ordered new ones, went about fitting them today, all good. Then I noticed one clip was lower than the other. Took the whole unit out and found that the wire had come off of one of the spools. Tried my damnedest to get the wire back over by stretching, but I'm just not strong enough. Ended up taking the motor apart and, just as I was removing the cover, the blasted spool the wires attach to just pinged out! So I have no idea how the wire was wound. I've tried looking at YouTube videos, but I'm not really getting results for 6n models, just newer.
    I'd like to fix if possible rather than replacing the whole unit, so does anyone know how to re-fit the motor spool? How many times do I need to wrap the wire around it? Any help would be appreciated.
    Thanks in advance,
    Ex.
  2. Re: Help with 6n Polo Window Regulator/Motor Please
    1840 Post(s)
    I have been where you are but it is impossible to put into words the way to do this apart from there being a lot of expletives.... it is a terrible task and why we would only fit full units as the 6N system changed thrice during production but all genuine parts have been dropped so it is a major problem.
    1 1 0
  3. Re: Help with 6n Polo Window Regulator/Motor Please
    Sep 2007
    Thanks for the reply Crasher.
    Yeah, there were a few choice words from me, that's for sure! So, are you saying it's just better to get a whole new unit then? There's no point in my spending another half day trying to re-spool the wire if it's going to be a nightmare. I was just trying to save a few quid!
    Cheers,
  4. Re: Help with 6n Polo Window Regulator/Motor Please
    1840 Post(s)
    Even after 35 years working on VW’s I still make mistakes but I try to avoid the repair of sub assembly’s in an attempt to save money as when you factor in my labour at £66 an hour you can’t usually make it work. If you PM me your cars reg, on Tuesday I can work out which unit you need and if anyone lists it.
    1 1 0
  5. Re: Help with 6n Polo Window Regulator/Motor Please
    Sep 2007
    Thanks Crasher, I'll shoot you a PM now.
  1. Electric window issues on 2010 Polo (6R) - broken regulator?
    By 10POLO in forum Polo - Derby - Lupo - Fox
    Last Post: 21-09-2017, 05:58 PM
  2. B6 window regulator motor bolts
    By paulw in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2016, 06:42 PM
  3. Polo Window Regulator Fault
    By steveb_online in forum Polo - Derby - Lupo - Fox
    Last Post: 30-06-2010, 10:35 PM
  4. Driver's door window regulator motor
    By andyapanel in forum Golf MK3 - 1993 - 1999
    Last Post: 12-10-2008, 09:47 AM
  5. Polo Electric Window Regulator V Plate 3 Door
    By sparkplug01 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-05-2008, 12:39 PM
