Thread: 1.2 TDi Bluemotion EGR error code...?
  1. 1.2 TDi Bluemotion EGR error code...?
    May 2018
    Essex
    I wondered if anyone might be able to shed some light on the following issue...
    Engine check light illuminated, so a trip to the local independent garage. A diagnostic reveals an error code of P0402, the mechanic tells me it's a problem with EGR Temperature Sensor.
    However, and here's the problem, apparently there's four EGR sensors and the error code doesn't denote exactly what one it is!!
    This means I could end up replacing multiple sensors until the faulty culprit is revealed?!?
    Car is a 12 plate.
    Any suggestions greatly appreciated
  2. Re: 1.2 TDi Bluemotion EGR error code...?
    Dec 2014
    Bedford
    42 Post(s)
    Check the measured values for all the temperatures of egt sensor 1,2,3 +4. Check these on a cold un started engine. They should all be the same which will be roughly the same as ambient. If one is reading something ridiculously different to the other 3 then thats your faulty sensor.
  1. Replies: 0
    Last Post: 14-05-2017, 12:51 PM
  2. fault code p2563 on mk6 1.6 tdi bluemotion golf .
    By grantjohne in forum Golf MK6 - 2009 - 2013
    Last Post: 25-01-2014, 06:18 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  4. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  5. Question error code
    By mark53 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2008, 10:22 PM
