Thread: Brake Calipers - Car shake?
Results 1 to 10 of 17
  1. Brake Calipers - Car shake?
    Jan 2013
    Scotland
    11 Post(s)
    Is it possible for a brake calliper to stick on at times, and hence cause vibration throughout my car whilst driving? Iíve had my car 4 wheel aligned , all wheels balanced. Brakes completely replaced but yet I still have vibration issues at times! It initially felt resolved, but over a few weeks now its starting to creep back. It could be Iíve just lost a weight on my wheel(s) since then, but Its driving me insane. Incidentally, my nearside front and rear disks were warped (confirmed by Audi), and was shaking quite violently when breaking, hence the replacement. Car had only done 13k miles at this point. Hence why im wondering; are the callipers sticking on as im accelerating and causing them to overheat/warp (eventually) and shake my car?
    Is there simple way to determine the status of callipers through VCDS monitoring at all during journeys? Sometimes it feels acceptable, but sometimes it feels definitely worse!
    Audi A6 3.0 BiTDI Black Edition
  2. Re: Brake Calipers - Car shake?
    70 Post(s)
    They can indeed. Same horse, different jockey but the other half had the same issue with her Passat. Turned out to be the O/S front caliper sticking on accasionally. Replaced it, all the vibrations went away.
  3. Re: Brake Calipers - Car shake?
    Jan 2013
    Scotland
    11 Post(s)
    Interesting... How did you diagnose it?
  4. Re: Brake Calipers - Car shake?
    70 Post(s)
    Blueing on the disc.
  5. Re: Brake Calipers - Car shake?
    Oct 2015
    GB
    Rear disc I gather?
    Its very common, front discs are less rare but does happen.
    Stuck piston on calibers causing heat on the disc and left for a while will end up in a warped disc
  6. Re: Brake Calipers - Car shake?
    Jan 2013
    Scotland
    11 Post(s)
    I'm no expert but it's coming through the seat, so possibly rear yes.. I'm going to get rear wheels rebalanced again tomorrow just to again rule this out. But since I've just put new discs and pads all round I'll probably also nip into the garage amd seel advice.
    Wouldn't be a warranty issue stuck calipers would it? Cars within 3 years.
  7. Re: Brake Calipers - Car shake?
    Oct 2015
    GB
    I wouldnít waste money Ona wheel balancing as by the text you speak of that wonít solve much.
    Changing pads and discs will not resolve an issue of a sticking calliper(s), if thatís indeed ur issue.
    Rear pistons on a callipers are threaded as you probably know if you have replaced the discs and pads of the rear, so my question is - was the piston stiff on rewind?
  8. Re: Brake Calipers - Car shake?
    Jan 2013
    Scotland
    11 Post(s)
    Both My nearside disks were warped and needed replaced. Hence wondering what caused that, suggestion could be sticking calipers. Not wanting to end up in the same warped position again soon so I'll take it to garage to assess
  9. Re: Brake Calipers - Car shake?
    Oct 2015
    GB
    Quote Originally Posted by gdallas View Post
    More than likely sticking rear callipers in this case then, or friction on the handbrake which will cause the same symptom of a stick piston calliper.
  10. Re: Brake Calipers - Car shake?
    Mar 2008
    9 Post(s)
    I had my brakes changed over the weekend (thanks shabazmo !)
    We found on removal that the front drivers side inner caliper had seized so yes they can stick. In my case I did not have any vibrations but I thought I would answer on the question of whether they can stick
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  1. Brake calipers etc
    By Redrafa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2017, 07:23 PM
  2. Are A4 (B8) and A5 brake calipers the same?
    By pilot5054 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 03-01-2013, 07:37 AM
  3. ATE brake calipers
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-08-2009, 03:41 PM
  4. Brake calipers
    By ballisma in forum Golf MK6 - 2009-2013
    Last Post: 08-06-2009, 10:20 AM
  5. Brake Calipers
    By Oggi1808 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2009, 06:28 AM
