Thread: vw sharan starting problem
  1. vw sharan starting problem
    Apr 2013
    uk
    hi i have vw sharan 2006 tdi 1.9. THe car had starting problem for few weeks and then one day car could not start at all. the mechanic changed starter solenoid and problem sorted but after about one week the car started again the same problem. car wont start straight away when you turn the key. it takes few senconds to start . Please help with this issue.
  2. Re: vw sharan starting problem
    Feb 2016
    manchester,uk
    14 Post(s)
    Heater Glow Plugs.
  3. Re: vw sharan starting problem
    Apr 2013
    uk
    Quote Originally Posted by f927 View Post
    Heater Glow Plugs.
    Thanks for your reply. Is it the one that is fitted underneath the car on the left side withing the heating box?
  4. Re: vw sharan starting problem
    Apr 2013
    uk
    Thanks for your reply. is it the one fitted underneath the car inside the heating box on the left hand side
  5. Re: vw sharan starting problem
    Feb 2016
    manchester,uk
    14 Post(s)
    They are 4 Heater Glow Plugs (similar to spark plugs) which are fitted on top of the engine,you will see them when engine cover is removed.
  6. Re: vw sharan starting problem
    1841 Post(s)
    A fault code read would be a good idea, the 2006 has glow plug monitoring which removes guess work.
  7. Re: vw sharan starting problem
    Apr 2013
    uk
    Thanks for your reply. i have tested all 4 glow plugs with multimeter and they all are giving zero resistance. then i took them out and tested battery as well and they all start glowing withing seconds. So glow plugs are fine i guess. if you have any other suggestions please send me message. so i can check for the problem.thanks again
  8. Re: vw sharan starting problem
    1841 Post(s)
    A fault code read, this would have eliminated the glow plugs themselves (but NOT the control system) as they are monitored on this engine.
  1. Please Help Sharan starting/idling problem
    By broggy77 in forum Touran - Sharan - Caravelle
    Last Post: 21-12-2009, 02:49 PM
  2. sharan starting problem
    By finchy61 in forum Touran - Sharan - Caravelle
    Last Post: 06-03-2008, 08:50 PM
  3. Sharan Starting problem...Stumped!!
    By kevdsn in forum Touran - Sharan - Caravelle
    Last Post: 08-09-2007, 09:44 PM
  4. sharan starting problem
    By kala1408 in forum Archive posts
    Last Post: 20-07-2007, 11:32 AM
  5. VW Sharan SE Auto intermittent starting problem
    By Broley in forum Touran - Sharan - Caravelle
    Last Post: 19-02-2007, 12:51 AM
