Thread: A6 tdi 2003 Sport intermittent acceleration problem
  1. A6 tdi 2003 Sport intermittent acceleration problem
    Jul 2017
    Hoping that some of you savvy mechanics may have some idea on this one. My A6 Avant has recently started to experience a problem when accelerating. It only happens when I am in low gears (2 &3) and always happens around town when I am driving slowly. For instance, I'll be driving along in 3rd at about 25mph and a car will slow in front of me. Rather than braking I'll lift my foot off the accelerator and slow down. When I then push down on the accelerator there is no response and I have to lift off and kick down on the accelerator - it then responds but you'll experience a judder as it's like the car has lost power. Similarly, if I change down it also happens. There are no problems at higher speeds.
    I can't find a pattern other than this. At first I thought it was a drop in the revs but this isn't always the case (thought I may have a leaking hose or something - lack of pressure).
    Any ideas anyone?
  2. Re: A6 tdi 2003 Sport intermittent acceleration problem
    May 2018
    Lancashire
    Is the car manual or CVT?
    Have you had it on VCDS, or a decent code scanner?
  3. Re: A6 tdi 2003 Sport intermittent acceleration problem
    Jul 2017
    Its manual and no, its not been on a scanner yet. When I took it to a local mechanic he seemed to shrug it off. Not helpful!
  4. Re: A6 tdi 2003 Sport intermittent acceleration problem
    May 2018
    Lancashire
    First things first, get it on a scanner. And that will give an idea if its boost etc related.
  5. Re: A6 tdi 2003 Sport intermittent acceleration problem
    Jul 2017
    Ok, I'll report back. Thanks for your time.
  1. Question VW Passat S TDi 2003 ESP-Air Bag Faults Intermittent Problem
    By Xaghra75 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2017, 05:55 PM
  2. Please Help Passat B5.5 tdi Sport Estate - Intermittent Alarm problem !
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-09-2013, 11:03 PM
  3. Please Help Intermittent momentary hesitation in acceleration about 3000rpm
    By silver4444uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-11-2012, 05:30 PM
  4. 2003 Audi A6 Multitronic 2.5 TDI Acceleration problems
    By Tired traveller in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-05-2011, 07:19 AM
  5. Intermittent Loss of Acceleration issue
    By Fatimoo1 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-01-2011, 06:31 PM
