Re: Bit of advice needed.... –
14-05-2018,09:28 AM
Originally Posted by
Pete_NorthEast
AND THE SAGA CONTINUES....
Filled all holes with bolts and silicone and thought job was sorted, big mistake. After the rain last night I opened the boot to find the spare wheel well filled with water, again
so got in car and had the wife spray water on the tailgate and the water is seeping out through the black silicone stuff under the tailgate, god knows what this is and even less what it’s used for (see pic), it’s also coming in from behind the black boot lock solenoid?? At least that’s what I think it is, anybody got any ideas????
I think the black stuff is a coating to stop the spare wheel from rubbing against the bodywork. When I had a rear end shunt in my 2012 A6, the body panels in that area were distorted and some of the seams had split open. I'd be looking behind the bumper and crashbar at the seams where the panels of the rear boot floor join.
You can see the seams I mean in the damage pics below (taken from inside the boot)
On the outside, they should be covered by waterproof sealing tape. I'd be checking this to make sure it's intact after your towbar guy was under there.
Cheers!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
