had low oil pressure warning then esp/traction/no brakes? coasted car to layby started again ok no lights warnings managed to get home did vag com on it
Friday,27,April,2018,17:33:17:31207
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ8E95A470740 License Plate: DG05EVW
Mileage: 142410km-88489mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E95A470740 Mileage: 142410km-88489miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 L HW: 4E0 907 560
Component: 4.2L V8/5V 0010
Revision: -------- Serial number:
Coding: 0011771
Shop #: WSC 06335 000 00000
VCID: 2E58C62EB96EA234BA-807A
2 Faults Found:
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU - Intermittent
16706 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal - Intermittent
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E0 910 156 M HW: 09L 927 156
Component: AG6 09L 4.2L5V RdW 0030
Revision: --H01--- Serial number: 0054281
Coding: 0000001
VCID: 3064D856A35AB4C4A8-8064
2 Faults Found:
18260 - Powertrain Data Bus
P1852 - 000 - Implausible Message ECU - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 38
Mileage: 142384 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 93.0
Temperature: 20.0°C
T.B. Angle: 60.0°
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 142410 km
Time Indication: 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004902
VCID: 2756330A9694F37C79-8072
3 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFFAB
Hex Value: 0x00FF
01315 - Transmission Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFF90
Hex Value: 0x00FF
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x6700
Hex Value: 0x4006
Hex Value: 0x00FF
Hex Value: 0xFFAD
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AK
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6AD00A3E16060E14A6-5120
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0303
Coding: 00021
Shop #: WSC 06335
VCID: 3972E5722320758C1F-4B18
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001WV3C
Coding: 0033622
VCID: 3B7EFF7A7A1C479C0D-806E
Subsystem 1 - Serial number: 6332DRB4015513AAI
Subsystem 2 - Serial number: 6342DRB40151D00DH
Subsystem 3 - Serial number: 6352ARB400440A0DD
Subsystem 4 - Serial number: 6362ARB400455DC1N
Subsystem 5 - Serial number: 63729RB400438C00A
Subsystem 6 - Serial number: 63829RB400438D1AN
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 01111
Shop #: WSC 06335
VCID: 41828D924BF02D4C57-4B18
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 P HW: 8E0 920 981 P
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0007441
Shop #: WSC 00640 512 00000
VCID: 3A70FA7E76267E9416-513C
2 Faults Found:
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007441
VCID: 3A70FA7E76267E9416-515A
2 Faults Found:
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BDE0F3A19FC171CDD-5120
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 06907
Shop #: WSC 06335
VCID: 7DFA3162778889AC73-4B18
Subsystem 1 - Part No: 8E2959802B
Component: Tőrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tőrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 3972E5727020758C1F-806C
End-------------------------(Elapsed Time: 06:04)--------------------------
Battery is a 10-1v sure I shouldn't d try an restart till fin what's wrong but I,ve no idea audi s b7 2005 at help very app currently stuck in me garage any help app thanks
