Thread: Broken down dpf light
Results 1 to 10 of 16
  1. Broken down dpf light
    Jul 2008
    Help needed!
    Was driving along and the dpf light came on, carried on driving and a eml light also came on p0299 which suggests a problem with turbo.
    Eventually the car lost power and cut out..
    If I try to start it is hard to start then won't Rev about 1000 before losing revs and cutting out, each time fumes are coming from the engine it seems.
    Any suggestions?
    Could the dpf need a manual regen and if so how can I do this using vdcs if the car won't start?
    Anything else I can try before garage time?
    Just waiting for aa as I speak!
  2. Re: Broken down dpf light
    May 2012
    Everywhere
    308 Post(s)
    Everyday is a dpf day ! Not fit for purpose .
    Partially blocked dpf puts back pressure on the turbo and can kill it .
  3. Re: Broken down dpf light
    Jul 2008
    Dpf only at 28g but somethings blocked... Not sure what tho
  4. Re: Broken down dpf light
    Jul 2008
    Runs of you take pipe to egr off, so something is blocked somewhere...
  5. Re: Broken down dpf light
    May 2012
    Everywhere
    308 Post(s)
    Egr , bin , dpf , bin .
    Engine runs forever and better with more power & torque inc mpg .
  6. Re: Broken down dpf light
    Jul 2008
    Didn't think you could get rid of dpf with new mot laws? I'd love too else...
  7. Re: Broken down dpf light
    May 2012
    Everywhere
    308 Post(s)
    What's your VIN plate smoke coefficient number ?
  8. Re: Broken down dpf light
    Jul 2008
    How do I find that?
  9. Re: Broken down dpf light
    May 2012
    Everywhere
    308 Post(s)
  10. Re: Broken down dpf light
    1840 Post(s)
    The DPF may have melted down but if it is just blocked the “The DPF Clean Team” in Hinckley are very good at sorting them out. The 28gram figure is the Ash, not the soot, if the reading is over 40% you cannot regen at all, the warning says “vehicle may burn down”. When you get a cleaned DPF back, you still must carry out a forced regen. I have a Passat in on Friday which has failed its MOT due to a Darkside Devleopments illegal DPF delete pipe and the poor owner bought it like this not knowing so not only does he have to pay £1800 for a new DPF but also the VW £400 surcharge as we can’t hand an old one back. I will be destroying the Darkside Developments delete pipe to prevent its re-use. With the recent negative press and now CLEAR fact that diesels without a DPF are killing thousands of people a year I find it difficult to understand why removing the DPF even crosses someone’s mind, how can people be so callous? Those advertising the service and selling the parts should be prosecuted.
  1. Wanted Broken Led Front indicator and Broken Led rear light Q7 Facelift.
    By Gavin0478 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 10-10-2017, 11:08 PM
  2. Light Sensor Broken?
    By microwork in forum Golf MK6 - 2009 - 2013
    Last Post: 09-03-2010, 03:33 PM
  3. Broken rear light
    By ali_a4_avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-07-2009, 07:18 PM
  4. fog light glass broken
    By jcb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2009, 11:47 PM
  5. B6 Cab - Rear light broken, can I upgrade to B7/B8
    By Blue Man Group in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-08-2008, 08:24 PM
