Thread: low oil pressure warning an enigine died
Results 1 to 8 of 8
  1. low oil pressure warning an enigine died
    May 2008
    low oil pressure warning came on along with no brakes no esp no abs etc engine dies coast do a stop in layby restarted k no warnings noticed battery at 11v (might not have been a good idea but didn't have advantage of internet)
    got home ran vagcom got this no idea
    Friday,27,April,2018,17:33:17:31207
    VCDS Version: 18.2.0.3 (x64)
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    VIN: WAUZZZ8E95A470740 License Plate: DG05EVW
    Mileage: 142410km-88489mi Repair Order:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUZZZ8E95A470740 Mileage: 142410km-88489miles
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 L HW: 4E0 907 560
    Component: 4.2L V8/5V 0010
    Revision: -------- Serial number:
    Coding: 0011771
    Shop #: WSC 06335 000 00000
    VCID: 2E58C62EB96EA234BA-807A
    2 Faults Found:
    18034 - Powertrain Data Bus
    P1626 - 008 - Missing Message from TCU - Intermittent
    16706 - Engine Speed Sensor (G28)
    P0322 - 004 - No Signal - Intermittent
    Readiness: 0000 0100
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 8E0 910 156 M HW: 09L 927 156
    Component: AG6 09L 4.2L5V RdW 0030
    Revision: --H01--- Serial number: 0054281
    Coding: 0000001
    VCID: 3064D856A35AB4C4A8-8064
    2 Faults Found:
    18260 - Powertrain Data Bus
    P1852 - 000 - Implausible Message ECU - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 38
    Mileage: 142384 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 93.0
    Temperature: 20.0°C
    T.B. Angle: 60.0°
    18265 - Load Signal
    P1857 - 000 - Error Message from ECU - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 142410 km
    Time Indication: 0
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
    Component: ESP8 quattro H04 0180
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004902
    VCID: 2756330A9694F37C79-8072
    3 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 35
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x00FF
    Hex Value: 0xFFAB
    Hex Value: 0x00FF
    01315 - Transmission Control Module
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 35
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x00FF
    Hex Value: 0xFF90
    Hex Value: 0x00FF
    18265 - Load Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x6700
    Hex Value: 0x4006
    Hex Value: 0x00FF
    Hex Value: 0xFFAD
    Hex Value: 0x00FF
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AK
    Component: A4 Klimaautomat 2731
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6AD00A3E16060E14A6-5120
    No fault code found.
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 J
    Component: int. Lastmodul ECE 0303
    Coding: 00021
    Shop #: WSC 06335
    VCID: 3972E5722320758C1F-4B18
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 0036M001WV3C
    Coding: 0033622
    VCID: 3B7EFF7A7A1C479C0D-806E
    Subsystem 1 - Serial number: 6332DRB4015513AAI
    Subsystem 2 - Serial number: 6342DRB40151D00DH
    Subsystem 3 - Serial number: 6352ARB400440A0DD
    Subsystem 4 - Serial number: 6362ARB400455DC1N
    Subsystem 5 - Serial number: 63729RB400438C00A
    Subsystem 6 - Serial number: 63829RB400438D1AN
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 01111
    Shop #: WSC 06335
    VCID: 41828D924BF02D4C57-4B18
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 981 P HW: 8E0 920 981 P
    Component: KOMBI+WFS 4 H12 0040
    Revision: 0040 Serial number: 00000000000000
    Coding: 0007441
    Shop #: WSC 00640 512 00000
    VCID: 3A70FA7E76267E9416-513C
    2 Faults Found:
    01304 - Radio
    Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
    Coding: 0007441
    VCID: 3A70FA7E76267E9416-515A
    2 Faults Found:
    01304 - Radio
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: 6BDE0F3A19FC171CDD-5120
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
    Part No: 8E0 959 433 BM
    Component: Komfortgerát T3B 2431
    Coding: 06907
    Shop #: WSC 06335
    VCID: 7DFA3162778889AC73-4B18
    Subsystem 1 - Part No: 8E2959802B
    Component: Tőrsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8E2959801B
    Component: Tőrsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0205
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0205
    1 Fault Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 B
    Component: Dynamische LWR H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000005
    VCID: 3972E5727020758C1F-806C
    End-------------------------(Elapsed Time: 06:04)--------------------------
    battery is at 10-11v
    so any help much appreciated
    thanks
  2. Re: low oil pressure warning an enigine died
    Sep 2008
    chester
    17 Post(s)
    First thing I'd do is get a decent battery and get the oil pressure tested immediately,that voltage is low and could be causing a host of spurious alarms,also check the output of the alternator see if its that or the battery.
  3. Re: low oil pressure warning an enigine died
    May 2008
    Quote Originally Posted by nevo View Post
    well put me tester on battery read 11 amps per hour an battery is 80amp charged overnight got it to a better 65 aph
    had starting prob before cranked3 times then died so yes think your right battery knackered not sure how I can test oil pressure but I now think battery is goosed show volts when running at 13 to just about t 14 only jus on 2 before I start
    thanks for reply
    app any others
    cheers
  4. Re: low oil pressure warning an enigine died
    May 2008
    Quote Originally Posted by shannei View Post
    thanks for reply
    app any others
    cheers
    well checked again tonight 11.7 volts it started ok off tester 38amp per hour so looking like battery is goosed, when running volts are 13.78 at battery ?
  5. Re: low oil pressure warning an enigine died
    Jan 2018
    Sussex
    55 Post(s)
    Its alternator load dependent, can be 15 if electric cabin heater is on.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  6. Re: low oil pressure warning an enigine died
    May 2008
    check battery 12.0volts started engine disconnected battery still running volts at terminals 14.34 volts from alternator
    so 1: battery looks no good by looks of it
    2:and still unsure how I can get oil pressure tested
  7. Re: low oil pressure warning an enigine died
    May 2008
    now wont start cranks over ok so lookin at a few forums crank sensor or fuel pump tried relay its ok asked how much to scrap it would get Ł1000 might be worth going that route then?
  8. Re: low oil pressure warning an enigine died
    May 2008
    yep crank sensor not oil pump or as some dope said on another forum your turbo will be busted if no oil pressure yeah right but all seems good now
  1. Question Karcher Pressure Washer Has Died. Please Help!
    By rapport25 in forum Chat - Completely Off Topic
    Last Post: 08-01-2012, 10:10 PM
  2. Tdi died and wont start,battery light came on before it died..
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2010, 05:44 PM
  3. Please Help enigine pipe missing
    By dizine in forum Golf MK3 - 1993 - 1999
    Last Post: 04-10-2010, 10:43 PM
  4. Replies: 8
    Last Post: 27-03-2009, 03:07 AM
  5. low oil pressure warning!!
    By w-s-m passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 08:46 PM
