Thread: Diagnostic Results - Egr valve?
Results 1 to 8 of 8
  1. Diagnostic Results - Egr valve?
    Apr 2018
    Wales
    I own a passat cc 2011 2.0 TDI gt blue motion
    My glow plug symbol started flashing and went into safety mode it seems to be intermittent because light is off again and has driven normally, tried to book in local VW garage but earliest was 8th of may. I had diagnostic done at local garage and results are attached (picture).
    codes were
    P040300 Exhaust gas recirculation circuit
    I have read up and apparently this could be the egr valve? Can this be cleaned or need replacing? If it can be cleaned any videos or instructions I could look at and how easy is it todo?
    U015500 lost communication with instrument panel cluster control module
    i have no idea what this is and garage didn’t explain very well
    thanks in advance for any help
    Ross
  2. Re: Diagnostic Results - Egr valve?
    Dec 2014
    Bedford
    42 Post(s)
    You will need a new egr, they are as reliable as a pensioners erection. Dpf needs removing and steering and subframe and os driveshaft. Part is around £320 plus vat and labour 5 hours. Longer if you take it to someone who has never done one before.
    Ps if you have had the cheat software update you might get it done for nothing from vw dealer.
  3. Re: Diagnostic Results - Egr valve?
    May 2012
    Everywhere
    308 Post(s)
    Egr's and dpf are only fit for the bin .
    Pensioner's.... more reliable as Viagra is available to them .
  4. Re: Diagnostic Results - Egr valve?
    Apr 2018
    Wales
    Thanks for the bad news lol.
    I read online the EGR valve can be cleaned? Is this not possible with my model car?
    As fault is intermittent is it worth trying Forté advanced diesel treatment?
    U015500 - what is this code all about or is it linked to ERG valve?
    Annoyingly the emissions letters didn’t get to me as I purchased around the time people were being contacted and previous owner didn’t forward on. I have spoke to vw and basically told me to F off I got no chance as I haven’t had the update done.
    Thanks for reply’s
  5. Re: Diagnostic Results - Egr valve?
    1840 Post(s)
    These EGR valves suffer from condensation inside the lid and this shorts out the circuits moulded into the lid and sends the car nuts, it can sometimes cause a crank speed sensor fault code which is a red herring.
  6. Re: Diagnostic Results - Egr valve?
    Dec 2014
    Bedford
    42 Post(s)
    Wouldn't waste a bottle of forte on it. You have a circuit fault so its most likely a solenoid valve fault on the egr like crasher said with condensation. Dont buy non genuine parts either as they are even worse than factory unit.
  7. Re: Diagnostic Results - Egr valve?
    Apr 2018
    Wales
    Ok cheers,
    so you guys think deffo only way forward is to replace EGR valve?
    Also read a lot of people blank/delete the EGR valve, is this a good or bad idea? Can it be done on my model?
  8. Re: Diagnostic Results - Egr valve?
    1840 Post(s)
    Replace the valve with a genuine VAG part or from the original supplier which is probably Siemens VDO. Removal of mandated emissions control systems is illegal and immoral.
  1. EPC Light - N276 Valve - Scan results...
    By .: JaCkPoT :. in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2013, 01:05 AM
  2. EGR valve removal, results, pictures and the woes
    By boidy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-08-2013, 03:11 PM
  3. Emission light on DIAGNOSTIC RESULTS from breakdown PLEASE HELP
    By Quattro25years in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 20-04-2013, 06:38 PM
  4. Help with vag-com results
    By dr x in forum VCDS - Help Requests
    Last Post: 06-06-2010, 06:48 PM
  5. VAG COM results
    By UK Damo in forum Golf MK4 - 1999 - 2004
    Last Post: 25-06-2009, 01:01 PM
