Thread: Audi A4 Quattro SE 2L Multiple faults
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Audi A4 Quattro SE 2L Multiple faults
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by techi View Post
    I did ask the question and was advised it was not crashed and i take that with a pinch, it doesn't appear to be crashed from looking under the bonnet etc but that's not to say it wasn't or at the very least it could have hit a small animal etc..
    Again I know what the logs say and if it walks like a duck it usually is. However its mine now and I intend looking after it as best I can and returning it to its former glory
    Yep, we never know etc...anyway, if you remove wheel housing liner, you see sensor, so to say front of the car, maybe just bad sensor or faulty wiring!
    https://ibb.co/iBUUm7
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
    1 1 0
  2. Audi A4 Quattro SE 2L Multiple faults
    Everywhere
  3. Re: Audi A4 Quattro SE 2L Multiple faults
    Oct 2012
    Estonia
    64 Post(s)
    Few ideas…
    1. Get a repair manual(you get pinouts from there etc)
    2.Airbag control module is under center console, crash sensor wires are running there.
    4.Generator error, might be related to one wire, which runs to gateway(if my memory correct, it has happened on others also)
    3.Check alternator output vs 13,7 on battery.
    4.If still oem battery, 8 years is plenty, no harm if you replace
    5.Few years back was one idiotic case here "black tape", so if you switch ignition on and no airbag light, check your cluster also, never know those idiots!
    6.As we dont know the history, i would check drivers airbag also, better safe then…..
  4. Audi A4 Quattro SE 2L Multiple faults
    Everywhere
  5. Re: Audi A4 Quattro SE 2L Multiple faults
    Oct 2012
    Estonia
    64 Post(s)
    Cheers you’ve me plenty to work on, I’ll try locate a repair manual first and take from there. Along with some reading on stripping the center console. Generator error wire to gateway I’ll read up on. Is there a way for me to check if battery is oem and again I’m assuming and maybe wrongly it would be date stamped somewhere.
    Thanks again I’ll come back when I’ve delved a bit further.
    If your battery has oem(by oem in previous post, i ment still from fractory 2010) battery part number sticker and bem code with barcode, which you can scan with phone app etc, my quess would be, in that case it is still factory one, as looks like previous owner only care about a dirty sale.
    Edit: Generator "tiny" linbus wire 0,35(purple-blue) will run to gateway pin2!
  6. Audi A4 Quattro SE 2L Multiple faults
    Everywhere
  7. Re: Audi A4 Quattro SE 2L Multiple faults
    #17
    Oct 2012
    Estonia
    64 Post(s)
    This car price was I guess low. Anyway, most of steering retros and repair manual also advising to disconnect a battery!
  8. Audi A4 Quattro SE 2L Multiple faults
    #18
    Everywhere
  1. Please Help Audi A6 S Line 2005 Multiple faults maybe or electrical fault?
    By mippy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-01-2016, 02:41 PM
  2. multiple faults
    By accy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2012, 08:59 PM
  3. Multiple faults with Comfort Databus
    By tazzz78 in forum VCDS - Help Requests
    Last Post: 19-03-2011, 10:40 PM
  4. multiple faults on dash
    By lonky in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-03-2010, 11:05 PM
  5. Audi A4 Quattro - Multiple Organ Failure
    By AlastairR in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-10-2007, 02:44 PM
