Thread: 01435 brake pressure sensor 1 g201 problem in electrical circuit
  1. 01435 brake pressure sensor 1 g201 problem in electrical circuit
    Apr 2018
    Leicester
    Hi guys !! Help needed here - I had abs and esp light on - mot station said I need to change the abs pump - I got a second hand one and changed it ( changed my abs ecu from old pump) .. the problem I have now is with the snap on machine it says module incorrectly coded and can’t code the new abs pump .... this might have nothing to do with it but I noticed a lot of water sitting in the battery compartment (drained now)
    I am based in Leicester and am willing to travel if anybody can fix this issue for me
  2. Re: 01435 brake pressure sensor 1 g201 problem in electrical circuit
    1841 Post(s)
    If this is a PQ35 platform (Golf 5, A3 8P, Octavia 2 etc) you can get a repair kit from VW under the part number 1K0 698 517 B for £303.55. It has be be installed very carefully and the system must be force pressure bleed in basic settings mode after installation.
  1. G201 Brake Pressure Sensor
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-05-2020, 09:26 PM
  2. P2294 Fuel Pressure Regulator Sensor Circuit
    By JDuBois in forum VCDS - General Questions
    Last Post: 29-01-2015, 12:35 PM
  3. Please Help Spongy brakes after dealer G201 brake pressure switch ESP repair
    By davey_boy in forum Golf MK5 - 2004 - 2009
    Last Post: 06-03-2014, 03:20 PM
  4. A3 01435 - Brake Pressure Sensor 1 (G201) Fault and others
    By grimzz in forum VCDS - Help Requests
    Last Post: 30-10-2011, 05:07 PM
  5. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
