Thread: P0183-Fuel Temperature Sensor Circuit High
  1. P0183-Fuel Temperature Sensor Circuit High
    Apr 2018
    North of England
    Hi guys, wondering if anyone can help, I’ve recently had to rewire my boost pressure sensor, since I’ve don’t that a new engine code of P0183 Fuel Temperatures sensor circuit high, can anyone tell me if that’s a wiring fault to, if they take the path as the BPS wire I I replaced. Thank you.
  2. Re: P0183-Fuel Temperature Sensor Circuit High
    Apr 2018
    North of England
    Anyone???
  3. Re: P0183-Fuel Temperature Sensor Circuit High
    Dec 2014
    Bedford
    42 Post(s)
    Highly likely, usually find the wires broken close to the gearbox in the loom. Ideally you should remove the multi plug from the ecu and test the wires for continuity from the ecu multi plug to the fuel temperature sensor (disconnected from sensor) and also the resistance, as close to zero ohms as possible and a max of 9 ohms. Be careful though i have seen the same colour wiring used twice in these looms in the engine bay so make sure your testing the correct pin designation numbers.
  1. Emisions workshop warning P0183 Fuel Temeperature Sensor fault code
    By Graham64 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-03-2018, 05:41 PM
  2. Please Help P0183 Fuel Temeperature Sensor fault code
    By Graham64 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-03-2018, 07:55 AM
  3. Engine coolant sensor circuit high
    By grahamjf in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2016, 10:51 AM
  4. Please Help Engine Coolant Temperature Sensor 1 Circuit High
    By sarah_a3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-06-2011, 09:42 PM
  5. Replies: 0
    Last Post: 24-01-2010, 12:57 PM
