Hi All,
A few days ago, the Touran ABS and traction control light of Touran turned on when my wife was driving. I used VCDS to check the error code and found the rear right senor had problem.
I would like to test the resistance of the rear right ABS sensor (bad) and compare it with resistance of rear left ABS sensor to determine if it is a senor issue or wire issue.
I know that for a saloon or hatchback car, the rear ABS sensor connectors can be found under the rear car seat. However, after I removed all three rear seats of the touran, I cannot find any connectors.
Does anyone know where are the rear ABS sensor connector in Touran (61 reg, 2.0 TDI, DSG)?
Thanks a lot,
Adsi
