Thread: Golf 1.4TSi Idle and Noise
  1. Golf 1.4TSi Idle and Noise
    Feb 2017
    Hi chaps,
    I've been having some intermittent problems with my car idling on cold start and some of the noises it has been making. On normal start up it fires to about 800rpm and all things considered, it is a really quiet car. However, it can sometimes go to 1,400rpm for about 5 seconds, drop down to 1,000 rpm for about 1 minute and then fall to the normal 800 rpm. During the time it is not in its normal rev range, the engine is rumbling and rattling while the car vibrates a little.
    This usually happens when the car has been sitting for a couple of hours in warm weather or sometimes after a long drive. It's not in regen mode as mine is a petrol. I've also notice that I'm slowly loosing a bit of coolant (hadn't checked for a few months and the tank was near empty - my previous cars didn't need topping up in 6 years!). I'm just a bit worried that the rumbling may be the water pump going or worse timing chain problems from some of the metallic noises I can hear.
    I've got some video of it (sorry sound isn't great) but you can hear some noise around when the car hits 1k rpm and is noticeably silent at normal 800rpm.
    Any thoughts would be appreciated guys. Thanks,
    https://youtu.be/EMgQ6ERLVac
    https://youtu.be/dXs4go8os7g
  2. Re: Golf 1.4TSi Idle and Noise
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    you should post up the engine code, year and mileage. You might have a timing chain tensioner problem causing the rattle. I've had a water pump fail and it did rumble at tickover then the seal failed completely and dumped all the water.
  3. Re: Golf 1.4TSi Idle and Noise
    Feb 2017
    Quote Originally Posted by Rob69 View Post
    It’s the CAXA engine with 44k miles on the clock, 2009 model.
  4. Re: Golf 1.4TSi Idle and Noise
    1840 Post(s)
    I would suggest a fault code read and a physical check of the valve timing.
  5. Re: Golf 1.4TSi Idle and Noise
    May 2018
    S wales
    Hi all new member hope you don’t mind me jumping in. I too had this problem on my sons 2010 golf 1.4 tsi, I have just replace the tensioner and chain, checked timing again and ok, but when I started up there is a metallic ticking noise and the car sounds like a diesel, can anyone shed any light on what can be the cause. Many thanks
  1. Question What to go for - Golf Mk6 1.6, 2.0 tdi or 1.4tsi?
    By Benl982 in forum Golf MK6 - 2009 - 2013
    Last Post: 12-02-2017, 04:15 PM
  2. 1.4tsi 122bhp idle speed
    By iallen1@btinter in forum Golf MK6 - 2009 - 2013
    Last Post: 04-10-2009, 09:43 AM
  3. Golf MkV 1.4TSI - Climate Control Tapping Noise / Not warming up
    By nnchokshi in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2009, 12:40 PM
  4. Golf MKV 1.4TSI remap
    By malaroo978 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-07-2009, 10:28 AM
  5. Where is the 1.4Tsi Golf
    By Stardelta in forum New Member Introductions
    Last Post: 11-05-2009, 07:32 PM
