Thread: Battery Voltages on an A6?
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Battery Voltages on an A6?
    May 2016
    London
    18 Post(s)
    I have read that + terminal getting hot is common on a6 and simple fix will sort this . Drive in a screw in from what i read it fixes for a lot of people
    Sent from my SM-G950F using Tapatalk
  2. Re: Battery Voltages on an A6?
    Jul 2013
    76 Post(s)
    Check the cable down to the alternator as if the cores go hard then this be the source of the resistance if you cannot find an insulation breakdown.
    Niedzial1983, the terminal has gotten hot as the cap has melted.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  3. Re: Battery Voltages on an A6?
    May 2016
    London
    18 Post(s)
    Quote Originally Posted by dan2485 View Post
    Try the screw fix. You have nothing to lose
  4. Re: Battery Voltages on an A6?
    Aug 2010
    St. Austell, Cornwall
    Quote Originally Posted by niedzial1983 View Post
    So, I just drive a screw directly into the cable? How is this meant to work? I presume it spreads the internal cores, and makes a better contact? I doubt it’ll do much for my voltage loss though? Do you have any links to other people/threads with this problem?
    Thanks, Ed.
  5. Re: Battery Voltages on an A6?
    May 2016
    London
    18 Post(s)
    Quote Originally Posted by eddie_fb View Post
    Thanks, Ed.
    Yes . Exactly in that place like on the pic. Its helps secure and connect the top of the cable to the botton after the 90 degree bend . The lose connection there is causing the heating
  1. Question Battery charger characteristics for battery voltage maintenance
    By Novica in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2016, 01:46 PM
  2. Replies: 0
    Last Post: 23-08-2015, 06:34 PM
  3. Shorted battery by accident now car won't start - battery is good...
    By Nookster in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2011, 06:32 PM
  4. Radiator control voltages
    By golf144 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-04-2011, 12:47 PM
  5. BATTERY LIGHT ON 2.7TDi Q 2005 - NO BATTERY CHARGE
    By shairaz1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 02:05 AM
