Thread: Should a 2005 Audi A6 (C6) be rusting this badly?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Should a 2005 Audi A6 (C6) be rusting this badly?
    108 Post(s)
    1816 Post(s)
    All typical rust blebs. You should see the chassis legs on some 4F’s, I saw a 2009 last week which I would say will have holes in the rear legs within a year or two. Modern cars are not built to last, very environmentally sensible.....
  2. Re: Should a 2005 Audi A6 (C6) be rusting this badly?
    Jun 2006
    Mine is a 2005 saloon, so far no rust and underside good too.
    Going to get it up on a ramp again soon and give it a good check over having seen this.
    It's a bit of a shock when you discover something like this as it's not really possible to fix long term unless isolated to parts that you can replace.
  3. Re: Should a 2005 Audi A6 (C6) be rusting this badly?
    108 Post(s)
    1816 Post(s)
    I see some trully horrific sights under modern VAG cars, not since the late 70's have I seen them rust like that
  4. Re: Should a 2005 Audi A6 (C6) be rusting this badly?
    Mar 2009
    Montenegro
    13 Post(s)
    I did not expect that Audi can rust like this. When I first time saw B5NUT A6 I had checked mine as well, but so far everything is clear
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  5. Re: Should a 2005 Audi A6 (C6) be rusting this badly?
    108 Post(s)
    1816 Post(s)
    I was doing a first service on a six month old A4 today and the rear floor is much better protected than I have seen over the last ten years and the Golf 7 is the same, thick rubberised floor coatings, like int gut olde days of Golf 2
  6. Re: Should a 2005 Audi A6 (C6) be rusting this badly?
    11 Post(s)
    I’ve got a 55 plate and it’s not rusting at all. I’m amazed there can be such a variation.
    55plate Audi A6 Avant. 3.0Tdi S-Line Quattro.
  1. Rusting/Corroding B6 Passats
    By maxgain in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-12-2015, 04:06 PM
  2. Rusting hubs
    By Silverfox666 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-01-2015, 05:15 PM
  3. Rusting Yeti
    By DDF in forum Yeti
    Last Post: 15-08-2013, 12:34 PM
  4. Roof Rails rusting!!
    By helly85 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 18-11-2010, 05:46 PM
  5. 2004 Passat rusting, what do you guys think?
    By Tysan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2008, 01:15 PM
