Thread: Replaceing NSF Park sensor 2002 Audi Allroad
  1. Replaceing NSF Park sensor 2002 Audi Allroad
    Nov 2011
    Duns Scotland
    11 Post(s)
    Hi all. Wonder if someone can help - I need to replace this sensor (one on order with touch up paint). It is located underneath the NS headlight. Now I have previously removed the bumper, headlight and wheel arch cover to deal with other jobs in the past. I am wondering if I remove the headlight (my preference) will I be able to access the sensor? OR if I remove the wheel arch cover can I do likewise? Last resort is to take off the bumper (easy too but a bit of a faf!).
    As I getting on a bit, I cannot remember! Hope someone can assist this old foggie.
    Many thanks,
    John
  2. Re: Replaceing NSF Park sensor 2002 Audi Allroad
    Sep 2009
    A406
    Ideally, you would need to unbolt the bumper without disconnecting anything just support it from hanging on its weight. What I did though was just released one side and had enough space to replace the sensor. You would also need bumper off to remove headlight as there is one screw from underneath but I don't think that is necessary. Be careful with bit it clicks into as it is easy to rip off if forced too much.
    V6 Tdi Power!
  3. Re: Replaceing NSF Park sensor 2002 Audi Allroad
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quick update, I replaced the nsf parking sensor whilst servicing the car. With the front noise insulation off you can get to this sensor from underneath - no need to remove anything else.
    OSF sensor maybe an issue though as there is an atf cooler at that side (forgot to look!) on my 2.5 AKE Allroad. Also, if you have a 2.7 Engine you may have issues as there are coolers on either side! For these instances it does not look to help if you remove the headlight as you still cannot access - so bumper has to come off!
    Finally, the headlight can easily be removed - the third bolt is accessible with a long reach 30torx screwdriver thru a hole in the lock carrier- you can also remove the bolt by reaching under with your hand - have done this a few times!
  1. AUDI A6 C5 AVANT 2004 tailgate - Will it fit my Audi Allroad 2002
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2016, 09:29 AM
  2. Audi A6 Allroad 2002
    By stoddy2k01 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-03-2016, 07:30 PM
  3. Audi 2002 A6 Allroad Ipod Connection
    By Schwayne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2012, 11:49 PM
  4. Replacing O-Ring for Oil Level/Temp Sensor on 2002 Audi Allroad 2.5 TDI Automatic AKE
    Last Post: 12-04-2012, 05:25 PM
  5. Replaceing Camshaft Sensor A3 1.6 1997 - Need some sort of guidance
    By seancullen in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-09-2011, 07:12 PM
