Thread: MK6 GTD DSG - Blue Smoke!
Results 1 to 10 of 12
  1. MK6 GTD DSG - Blue Smoke - Not your usual!
    Apr 2018
    Swindon
    Hi all, I have a MK6 GTD, I have blue smoke coming from rear under acceleration whether its hard acceleration of lightly using the throttle. It plumes out the back, mixed with a bit of black apparently too.
    Previous owner told me it didn't do it when low on fuel (seems to be accurate) Seems to be a key point this <----
    Turbo has been changed, all other associated parts checked and replaced, breathers have been double checked.
    DPF has 0mg inside.
    DPF seems to constantly regenerate after EVERY drive. (fans still blowing when engine off)
    It has had a cheap remap, which I wasn't aware of when I bought it.
    Seems to not happen when the tank range is below 50 miles..
    C02 Sensor fault too!
    If I remember any other details I'll update the thread.. Thoughts on the problem?
    Cheers!
  2. Re: MK6 GTD DSG - Blue Smoke!
    Jul 2015
    Staffs
    46 Post(s)
    Scanned for codes?
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: MK6 GTD DSG - Blue Smoke!
    Apr 2018
    Swindon
    Yeh o2 censor forgot to put that up.
  4. Re: MK6 GTD DSG - Blue Smoke!
    1836 Post(s)
    Get it re-flashed to normal BUT not the emissions recall version and replace the sensor. If there is black smoke the DFP isn't working so I can't see how it would show 0% soot load coefficient and what about the ash content ml? Do you know if the DPF is actually inside the canister?
  5. Re: MK6 GTD DSG - Blue Smoke - Not your usual!
    Jan 2018
    Sussex
    55 Post(s)
    DPF most likely.
    No regen on low fuel warning - no smoke !
    Maybe cheap aftermarket DPF unit or bad remap.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  6. Re: MK6 GTD DSG - Blue Smoke!
    Apr 2018
    Swindon
    Booked in this evening to get a stock map put back on. According to VCDS dpf shows: 0ml Oil ash volume, 0.3 Carbon mass (spec.) 10.2 Carbon Mass (act.)? Hopefully that tells you more than I can understand.. Lol
    Quote Originally Posted by Renars View Post
    DPF most likely.
    That makes sense! Orgininal VW DPF is still on, booked in for a stock map later today.
    That only explains the black smoke though, I'm more concerned over the blue?
  7. Re: MK6 GTD DSG - Blue Smoke!
    Jan 2018
    Sussex
    55 Post(s)
    There is plenty of blue smoke on regens. Especially if something’s wrong.
    Current cars:
  8. Re: MK6 GTD DSG - Blue Smoke!
    Jun 2008
    7 Post(s)
    0ml oil/ash, surly this must be a
    Sensor
    problem or has been switch off via software?
  9. Re: MK6 GTD DSG - Blue Smoke!
    Mar 2011
    S/land UK
    No DPF internals ?
    Audi A6 AllRoad 2.5tdi (sold) Golf mk5 2.0 Gttdi 4 motion (sold)
    Jaguar S type 2.7d Sport (sold)Golf mk4 1.9 Gttdi (sold)
    Audi A6 1.9 Sport (sold)
    Golf mk6 GTD (sold)
    Golf mk7 GTD
  10. Re: MK6 GTD DSG - Blue Smoke!
    Jun 2008
    7 Post(s)
    Quote Originally Posted by dervdave View Post
    No DPF internals ?
    Would that not throw an error if the DPF had no internals.
  1. Blue Smoke
    By dingell in forum Touran - Sharan - Caravelle
    Last Post: 02-09-2010, 10:21 PM
  2. Blue smoke
    By krispy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-06-2010, 10:45 PM
  3. 99 1.8t blue smoke
    By sparky79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2009, 08:47 PM
  4. Blue Smoke
    By landi_idiot in forum The Commercial Range
    Last Post: 17-08-2008, 04:46 PM
  5. A6 2.5 Tdi - Blue Smoke
    By mrhope2933 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-07-2008, 07:59 AM
