Thread: Audi A4 B6 1.9tdi
  1. Unhappy Audi A4 B6 1.9tdi
    Apr 2018
    Lancaster
    hello fellas!
    so here we go, earlier today was driving up the by-pass and then all of a sudden the car makes a small jolt, throws the traction control light on, the glow plug system light and oil pressure light. the rev gauge was going haywire like it had a mind of its own, the steering went heavy and had no throttle response. so I pulled over switched the old girl off and first thing I checked was the timing belt and aux belt, both present and no signs of damage at all, no oil leaks either. so I went for the restart and everything was fine, no warning, steering was perfect and good throttle response. so I set off down the road again, about a mile down the road it happens again but this time the glow plug light flickered on and the abs light came on, no oil pressure light but the rev gauge was still playing up, switched it off while cruising and went for the rolling restart and been fine since. any help or somewhere to start checking would be much appreciated.
  2. Re: Audi A4 B6 1.9tdi
    1837 Post(s)
    If it affected the steering weight it has to be something to do with the front pulley arrangement and suggestions of a charging problem would point to the alternator locking up or the belt tensioner failing due to a locked up alternator one way clutch.
  3. Re: Audi A4 B6 1.9tdi
    Apr 2018
    Lancaster
    thank you for the reply Crasher. if it was the alternator, would it be possible that its back feeding and its that what's sending the rev gauge haywire?
  4. Re: Audi A4 B6 1.9tdi
    1837 Post(s)
    I can’t check the wiring diagram at home but we have had some odd responses to low batteries recently. Modern starter motors are capable of cranking over on what is really a flat battery but the battery can’t support the ECU.
  5. Re: Audi A4 B6 1.9tdi
    Apr 2018
    Lancaster
    Legend! ill check the battery at work tomorrow and let you know what I find, thank you buddy.
  6. Re: Audi A4 B6 1.9tdi
    Jul 2015
    Staffs
    46 Post(s)
    With all the recent wet weather and VAGs inability to make watertight cars i would also check for water ingress. Check foot wells and under the scuttle panel.
    Ian
    A4 B6 Avant Nogaro Blue
  1. Question audi a3 1.9tdi
    By chevwaltz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 05-09-2014, 04:21 PM
  2. First Audi - C5 A6 1.9TDI
    By Adam Watson in forum New Member Introductions
    Last Post: 23-01-2012, 08:36 PM
  3. Question Audi A4 1.9tdi pd
    By ronni in forum New Member Introductions
    Last Post: 05-05-2010, 10:25 PM
  4. Replies: 13
    Last Post: 01-04-2008, 02:24 PM
  5. Audi 801.9tdi
    By baggabones in forum 80 - 90
    Last Post: 24-07-2007, 06:24 PM
