Thread: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    Due to the snow my A6 unfortunately died, so I now have an A4 B7 2.0Tdi sline 170.
    As im new to these engines I need a bit of help working out what is normal and what isnt.
    I had to buy in a bit of a hurry, but the car seems pretty sound, however there are a couple of things which im not so sure about.
    In order of when they appear, i have the following things happening.
    In the morning or at the end of a working day when I start the car it doesnt start immediately - it requires turning over a few times before it goes.
    When it is going the idle "seems" a bit lumpy - although being used to the V6tdi i dont know if the 2.0 is just a bit like that - its idling around 780rpm.
    It also seems that occasionally when you boot it from low revs it just stutters a bit - almost like its missing, but then when the revs pick up its fine.
    I have had vcds on it, and there are no DTC's logged - ive looked at the injector readings and the all seem within the tolerance - all hovered around -0.5 to +0.5.
    I have contacted Audi, and they say it has no outstanding recalls on it - so I must assume the injector recalls on this model have been done if needed.
    Ive run injector cleaner through, and also re-oiled and cleaned the K&N panel filter it came with.
    Its doing around 40mpg on a run and 34 around town?
    Any ideas where to look to see what might be causing the above oddities?
    I have vcds, but am not particularly experienced in using it other than resetting faults and now looking at the injector values!
    The other small thing is that 2nd gear isnt directly down from first, is that normal? It seems a bit annoying because if I am changing from 1st to 2nd quickly i often get caught because I have to just slightly pull down and to the right to get second - again I dont know if that is normal and if not how I go about fixing it?
    Any help or suggestions etc.. much appreciated :-)
    Thanks.
  2. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    looks like you may need a new mass air flow sensor that oiled air filter is not recommended as it covers the MAF elements with oil i would take that air filter out and use a genuine one and replace the MAF
  3. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    Is there anyway of diagnosing that using vcds?
    From what I heard the oil on the K&N shouldnt harm the MAF - I personally wouldnt have put the filter in there, but seemed harmless enough so I have left it in there....
  4. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
  5. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    Tried the disconnect maf sensor trick and the engine seemed a lot smoother so plumped for a new maf, installed tonight and will see if it has sorted things tomorrow!
    Any thoughts on second gear?
  6. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    Is your car 6 speed manual front wheel drive?
  7. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    No its the 6 speed quattro.. Manual...
    Quote Originally Posted by arman123 View Post
  8. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    did the maf work and were did you get it from ?
  9. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    as for 2nd gear you could try this adjustment
    Adjusting selector mechanism
    The following are prerequisites for correct gear lever alignment:
    l Gear selector linkage must be in proper condition and undamaged.
    l Selector mechanism must move freely.
    l Gearbox, clutch and clutch mechanism must be in proper condition.
    l Gearbox in neutral.
    Procedure
    Remove gear knob together with boot → Chapter.
    Vehicles with large radio slot:
    Remove operating and display unit for air conditioner → Rep. Gr.87.
    Vehicles with small radio slot:
    First lift trim panel -1- in direction of -arrow A-, then pull it out in direction of -arrow B-.
    All models:
    Unscrew bolts -arrows C- and then pull ashtray -2- out of centre console.
    Unplug electrical connector for ashtray light.
    Remove foam wedges from centre console.
    Lift out the noise insulation.
    Unscrew noise insulation for selector housing -arrows-.
    Measure distance -a- between the two studs in the selector mechanism.
    l Specification: distance -a- = 85 mm.
    Note
    Measure from centre of one stud to centre of the other.
    If distance -a- does not meet specification:
    Loosen bolt -arrow- for push rod.
    l Rear push rod (in selector mechanism) should move freely in both directions on slide.
    Set to distance -a- by moving rear push rod (in selector mechanism).
    Tighten bolt for push rod -arrow- to 23 Nm.
    Loosen bolt for selector rod -arrow-.
    l Connection between selector rod and selector mechanism should move freely.
    Align the gear lever as follows:
    Centre the bottom of the gear lever in the centre of the ball guide.
    l Distance between ball guide and bottom of gear lever -arrows- must be the same at all points.
    Align gear lever so that it points slightly (3°) to the right (as seen in direction of travel).
    Hold gear lever in this position.
    Tighten bolt for selector rod -arrow- to 23 Nm.
    Note
    The gear lever must remain in the same position while the bolt is being tightened.
    Power transmission > 6-speed manual gearbox 01E, four-wheel drive > Gearbox mechanics,operation, construction,diff. > Servicing selector mechanism > Adjusting selector mechanism
    Checking gear lever adjustment
    l The gear lever should rest in the 3rd/4th gear gate when the gearbox is in neutral.
    Press clutch pedal.
    Select all gears several times.
    Check operation of reverse gear lock.
    l The gear lever should return by itself from the reverse gear gate to the 3rd / 4th gear gate.
    If the gear lever sticks or baulks repeatedly when engaging a gear, perform the adjustment procedure again.
    Install trim parts and gear knob.
    Power transmission > 6-speed manual gearbox 01E, four-wheel drive > Gearbox mechanics,operation, construction,diff. > Servicing selector mechanism > Checking gear lever adjustment
  10. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    Jury is still out on the MAF - I though it had worked as it seemed much smoother this morning on my commute, however about 50 miles in on cruise control at 70 the car suddenly started to pulse a bit, but it was pretty much at my exit junction, so I wasnt sure if it was a cruise control oddity or something more sinister, but it did seem that at the lights through town to work, the engine had gone back to being a bit lumpy on tickover.
    So i'll see what its like tonight on the way home. MPG did seem up tho...
    I got it from eurocar parts - its a HAAS unit - although after reading up last night on MAF's i wonder whether I should have paid the extra £15 for the BOSCH unit.. :/
    My old one was pretty sooty i noticed, but did it quickly last night. Presume they dont need recoding or anything as I dont have any ECU faults.
    I am getting a glow plug fault on cylinder 2, but im guessing that wont cause me any issues - my 2.7Tdi had 5 glowplugs gone and I never had any problems with that...
  1. 2002 2.0FSI A4 Avant...Lumpy/low idle RPM sometimes hard to start. WHY?
    By j3aay in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2011, 11:51 PM
  2. Question Lumpy idle/slight missfire/lack of power.
    By Piggles in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-04-2010, 03:06 PM
  3. Hard starting/low or flat acceleration
    By Solution in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2009, 09:54 PM
  4. Hard starting/low acceleration
    By Solution in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-10-2009, 04:04 PM
  5. Slight rocking when starting and idle
    By Leavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2008, 08:58 AM
