Thread: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
Results 11 to 20 of 26
  1. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    MAF always buy genuine part you can exchange your old one at TPS PARTS
  2. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    Yeah I thought that after reading last night.
    Presumably the one I have will still read OK, but just maybe not last as long? or is it potentially likely that its not going to read well enough for the engine to run well?
    I assumed that as HAAS have a formula 1 team it would be ok :-D
  3. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    It's been a few days with the new maf and I dont think it's cured the problem.
    Had it really bad today really leapfroggy in first stuck in traffic and missing quite bad, but fine on the motorway.
    I've read it could be the exhaust cam timing out, is that likely and can I adjust that using vcds?
    Anything else it could be?
    Seems worse almost when it's hot, don't seem to have the same problem when it's cold.
    Quote Originally Posted by carbonman View Post
  4. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    when was the cam belt last changed ? check the torsion value in vcds engine group 4 should be 0° +/-0.5° also replace the fuel filter take the old one off empty the contents into a jar and see if any oil in fuel
  5. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jul 2008
    Cheers for that.
    Odly enough the engine management light came in this morning showing a fault with the maf so I'm going to exchange the haas unit with a bosch one on Monday. I've also bought a new fuel filter too, so hopefully they will help.
    If not I'll start looking at other things like timing.
    Will keep you posted!
    Thanks for the help so far
  6. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    Jan 2009
    Birmingham
    35 Post(s)
    What’s the engine code on yours
  7. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    #17
    Jul 2008
    Brd 039858
  8. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    #18
    Jan 2009
    Birmingham
    35 Post(s)
  9. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    #19
    Jul 2008
    New genuine bosch maf on, no difference, next stop fuel filter...
  10. Re: New car to me, few oddities - not starting immediately, lumpy idle and slight miss on hard acceleration.
    #20
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    could also be your injector wiring harness breaking down.
  1. 2002 2.0FSI A4 Avant...Lumpy/low idle RPM sometimes hard to start. WHY?
    By j3aay in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2011, 11:51 PM
  2. Question Lumpy idle/slight missfire/lack of power.
    By Piggles in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-04-2010, 03:06 PM
  3. Hard starting/low or flat acceleration
    By Solution in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2009, 09:54 PM
  4. Hard starting/low acceleration
    By Solution in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-10-2009, 04:04 PM
  5. Slight rocking when starting and idle
    By Leavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2008, 08:58 AM
