Thread: Weirdest vibration issue !!!
Results 1 to 10 of 13
  1. Weirdest vibration issue !!!
    I have a 2010 2.0 tdi A5 which has recently developed a really weird fault. I do the same commute to work every day and after roughly 10-15 minutes of driving, while I'm on the motorway, a vibration starts through the steering wheel along with a low frequency drone. At first I thought wheel balancing but it disappears after around a minute and doesn't come back for the rest of the journey (around 40 minutes). It doesn't seem to be speed related either as I've slowed down/sped up etc but still the same. I've also dipped the clutch to make sure it's not dual mass flywheel related. I had the wheels balanced as a matter of course but still no good. Really strange fault and quite annoying, anyone got any ideas ?
    Cheers,
    JJ.
  2. Re: Weirdest vibration issue !!!
    Nov 2010
    Shetland & S.Tyneside
    76 Post(s)
    At the risk of saying something stupid, could it be a section of motorway road surface, failing that have you tried swapping front wheels to back?
  3. Re: Weirdest vibration issue !!!
    12 Post(s)
    222 Post(s)
    The MLP platform is very prone to lower ball joint wear which causes odd wheel vibrations and we are starting to see a few racks fail due to internal wear on early cars like yours.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  4. Re: Weirdest vibration issue !!!
    Thanks for the reply Rob69 but no, it happens on different sections of road but always after about 15 minutes driving. I could swap the wheels but can't get my head around the fact it dissappears after a minute or so ??!!
  5. Re: Weirdest vibration issue !!!
    Thanks Crasher, I'll certainly have a look at the lower ball joints but still don't understand how the problem disappears ?!!
  6. Re: Weirdest vibration issue !!!
    12 Post(s)
    222 Post(s)
    That could suggest a heat related change in something which would normally point to a tyre, what is it on?
  7. Re: Weirdest vibration issue !!!
    So the car is a 2010 2.0 tdi Sport running on 245/40/R18. I've given the tyres a once over and no sign of flat spotting or uneven wear. I'll give the lower ball joints a look this weekend though and then maybe go for tyres.
  8. Re: Weirdest vibration issue !!!
    12 Post(s)
    222 Post(s)
    What make and version of tyres?
  9. Re: Weirdest vibration issue !!!
    Yokohama AE50 (W Rated)
  10. Re: Weirdest vibration issue !!!
    12 Post(s)
    222 Post(s)
    Not known for carcass issues so ball joints and rack play check first
  1. Weirdest defect i have ever seen: Metal plate appeared in fuel filler
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-01-2017, 11:18 PM
  2. Please Help A6 tdi 2,0 2007 vibration. Timing issue?
    By edfl in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-11-2015, 11:01 AM
  3. Please Help Vibration issue after remap / tuning box
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-10-2015, 12:55 AM
  4. audi a6 3.0tdi avant tiptronic vibration issue
    By jp33 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-09-2015, 08:59 AM
  5. S4 v8 vibration issue ?
    By buck22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2009, 09:56 AM
