Thread: Golf 1.6TDI Seized water pump
Results 1 to 10 of 20
  1. Golf 1.6TDI Seized water pump
    Feb 2006
    Hi all,
    My wife was driving her 2009 1.6TDI Golf the other day and at low speed she heard this screech and the car stopped. Natuarally she tried to start it again but no luck. It was recovered to the nearest garage who have had a quick look and confirmed the water pump had seized resulting in the timing belt jumping and there could be extensive damage to the engine. They are going to investigate further later this week but said prepare yourself for bad news as they will need to take the head off to see the extent of the damage.
    My questions are, would a seized water pump cause these symptons and possible damage?
    Shall I just cut my losses and sell the car for spares or repair or shall I let them take the head of and take it one step at a time?
    One thing I did notice is I had to top up the coolant a week or so ago as the warning light came on but it seemed fine until the catasrophic engine problem.
    The car has recently been serviced, has done 98k and had the cambelt and water pump changed at the correct intetrval albeit by an independant.
    Many thanks in advance
  2. Re: Golf 1.6TDI Seized water pump
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    A seized pump would strip or snap your belt and do the damage described. The pump was probably leaking a bit ( you having to top up the coolant) and the bearing got contaminated by the water or vice versa where the worn bearing and vibration wrecked the pump seal, either way, eventually seizing.
    Depends how much damage there is inside - if a conrod has been bent and piston crown damaged then probably beyond economical repair, if the pistons and rods are ok and just bent valves then maybe a recon head will be enough, but lots of labour + parts, so still expensive. It's mad when a 9 year old car could be scrapped off for bits due to this.
    I almost had the same on a petrol polo where the pump seal leaked but not enough to be obvious or needing topping up, but the bearing was shot by the coolant as the leakage tell tale hole was crusted up and blocked, only thing that made me look at it before total failure was an odd rattle from the engine at tickover.
  3. Re: Golf 1.6TDI Seized water pump
    Jul 2015
    Staffs
    46 Post(s)
    How old was the pump?
    Ian
    A4 B6 Avant Nogaro Blue
  4. Re: Golf 1.6TDI Seized water pump
    134 Post(s)
    2021 Post(s)
    When was the cambelt last changed.
  5. Re: Golf 1.6TDI Seized water pump
    Feb 2006
    Quote Originally Posted by rowdy-999 View Post
    Around 3.5 - 4 years
  6. Re: Golf 1.6TDI Seized water pump
    Feb 2006
    It was changed the same time as the water pump, 3.5 to 4 years ago. Wouldn't think it would have failed in that space of time.
  7. Re: Golf 1.6TDI Seized water pump
    Feb 2006
    Bad luck, there was no audible warning, just the slight coolant loss then.........££££££
  8. Re: Golf 1.6TDI Seized water pump
    Nov 2010
    104 Post(s)
    Depends on the quality of the pump installed last time, plenty of rubbish ones knocking about, just googled and found one for £9.99! My polo pump had done about 70k on original pump before failing, saying that though my previous passat pd tdi had done over 100k on original pump with no leaks but a bit play in the bearing.
  9. Re: Golf 1.6TDI Seized water pump
    Feb 2006
    Quote Originally Posted by Rob69 View Post
    Exactly, I have asked the question from the garage that fitted it but he's done work for me for years and has always used good quality parts.
  10. Re: Golf 1.6TDI Seized water pump
    Nov 2010
    104 Post(s)
    It's difficult to know where they come from and what is a 'quality' part these days!! some distributors are supplying cheaper parts with German sounding names but what look like far eastern origins but hard to pin down exactly what you're getting.
  1. Replies: 2
    Last Post: 06-03-2015, 12:01 PM
  2. Water Pump on a 1.6tdi mk6 Golf
    By matthew2riches in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2013, 08:07 AM
  3. water pump audi a6 & vw golf
    By lee1970 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-12-2012, 08:56 PM
  4. golf vr6 auxillary water pump
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 16-12-2010, 11:08 PM
  5. Golf TD water pump.
    By RAY THE BASS in forum Golf MK3 - 1993 - 1999
    Last Post: 16-02-2009, 08:27 PM
