Thread: Audi C7 Retrofit Phone Prep
  1. Audi C7 Retrofit Phone Prep
    Jul 2017
    Liverpool
    Hello,
    Bit of an odd question but hoping someone can help me reverse engineer what I need as I may already have many of the parts....
    To my A6 C7 2013 I retrofitted the AMI to the armrest using the kufatec kit, unfortunately at the time I couldn't get the replacement tray I wanted so ended up with the one for the phone prep in the armrest, I then brought the phone prep adapter (4G0862401) to fill the hole. Once I put the kit in there were no wires to connect it up to so pretty sure I'm missing something to have this feature as a nice side-effect of putting in the AMI.
    Please could someone help me with what parts are missing to have the phone prep installed properly in the armrest specifically where the two wires from the phone cradle are plugged into and whether any additional coding is needed?
    I have the RMC Nav Plus (two SD cards, no sim card head unit) and bluetooth enabled for calling so would suspect that there is a microphone and antenna already set up and working but even with ELSAWin I struggled to work out what other bits are needed.
    Thanks in advance!
  2. Re: Audi C7 Retrofit Phone Prep
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Quote Originally Posted by Acquell View Post
    Hello,
    Thanks in advance!
    I would like to add the phone cradle, did you get anywhere with this?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Audi C7 Retrofit Phone Prep
    Jul 2017
    Liverpool
    Quote Originally Posted by dean warren View Post
    Hello,
    I didn't manage to work it out sadly, think it may be a case of needing the more advanced phone prep. Believe the unit goes somewhere near the footrest on the drivers side.
    In the end decided as an iPhone owner the cradle wasn't going to give me much more as the AMI charges the phone and the bluetooth is pretty good anyway. I've been looking at CarPlay retrofits as they look like they may be pretty useful.
    Let me know if you find anything else out, ELSAWin seemed to show the part I have but no details about what it connects to so thought it may be the phone prep high or whatever it's called.
    Good luck!
  1. Replies: 0
    Last Post: 28-04-2015, 09:01 PM
  2. Is it possible to retrofit mobile phone prep?
    By ldzpmh in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-04-2013, 10:29 AM
  3. Audi A6 phone prep cradle replacement? Is it possible?
    By Infinity_UK in forum In Car Entertainment
    Last Post: 25-01-2013, 04:29 AM
  4. Retrofit Phone prep low?
    By UVB in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-07-2012, 03:20 PM
  5. Retrofit RNS-E with phone prep and bluetooth
    By EddieUK in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-03-2011, 10:31 AM
