Hi all.
I'm in need of some guidance. I've an Audi a6 in my workshop at the moment. It has been delivered to me from a body shop where they have installed full led headlamps. I'm not sure if these were the same as the originals or if they have been changed to these. i will have to ask the bodyshop questions tomorrow.
The issues are: when the light switch is set on auto or dipped - they appear to be working as intended. the main beam works as well. When the light switch is set to side lamps i've nothing at the front of the car - the rears light up as they should.
Scan shows various light fault codes - I've included a full scan report.
Can anyone shed some light on these issues? if more info is needed I may not be able till reply until sometime tomorrow.
Thank you for your time in looking/responding.
Saturday,14,April,2018,14:27:40:43818
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
Ross-Tech: Home
VIN: WAUZZZ4G4DN046428 License Plate: JB10 CKJ
Mileage: 77297km-48030mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 3B 42 44 46 52 53 55
56 5F 62 6C 72
VIN: WAUZZZ4G4DN046428 Mileage: 77297km-48030miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CDUD) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 Q HW: 4G0 907 401
Component: 3.0TDI EDC17 H39 0002
Revision: 53H39---
Coding: 0A254012052601020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
ROD: EV_ECM30TDI0114G0907401Q.rod
VCID: 313C1C8DF1A3E82FCD6-8064
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G1 927 156 T HW: 0B5 927 156 J
Component: 0B5 30 TDIRdW H01 0003
Revision: --H01--- Serial number: 0000000943
Coding: 000001
ASAM Dataset: EV_TCMDL501021 001009
ROD: EV_TCMDL501021.rod
VCID: 3E2637B130FD0757404-806A
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 27A68701E465E180CB00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 36362F9118CDCF17984-8062
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H32 0421
Revision: 00002001
Coding: 01B83046000000000000
VCID: 77A8E2955FC7F61F432-8022
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000152629003
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 08081200041076
Coding: 362100B821
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 629EA3C1E4C503B704C-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001396992
Coding: 0907201009749FE00181008300001800CF9DC3082F08020100 0108546F00
VCID: 6FB8DAF52797BEDF9B2-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120707 H36 0080
Serial number: 120720034923
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20481432
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 08 08 2012 00000459
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000029111600010011
Coding: 000000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000001121600010097
Coding: 000000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 6A180146000000000001
8 Faults Found:
02235 - Stationary Cornering Lamp (Left) (M51)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
03806 - Highway Lights Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
02236 - Stationary Right Cornering Lamp (Right) (M52)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
03807 - Highway Lights Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 77297 km
Time Indication: 0
Date: 2018.04.13
Time: 16:01:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061222202404
Coding: A8C306
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77A8E2955F47F61F432-8022
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG009UABC
Coding: 30323436313330303537554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40651G7FACOOR
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB40631G7FAEH0/
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40024UIV4EQB0
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB40631D2ASIG56
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40611EVLKF06X
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405T1EVLK30TT
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120813000540
Coding: 000034
VCID: 303A1989FA29E127C28-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 983 C HW: 4G8 920 983 C
Component: TDieGb H79 0515
Revision: 28460207 Serial number: 658020812596034
Coding: 33A608000B412600010000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 3534289D05CBC40F91E-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000639393
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001016
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 71BCDC8D3123A82F8D6-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790725653
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 01061200000000000574
1 Fault Found:
12291 - Energy Management Active
U140B 00 [008] - -
[Powermanagement active]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 129
Mileage: 77294 km
Date: 2018.04.12
Time: 14:44:16
Voltage terminal 30: 11.3 V
Voltage terminal 15: 11.3 V
Control Module temperature: 22 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 2
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 7CA2FDB966E1D5472E0-8028
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0076
Serial number: 06081200040275
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 372822951FC7361F832-8062
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H02 0053
Revision: -------- Serial number: EJ1BPA7200Z8DG
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
VCID: 333016850BBFDA3FBFA-8066
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011F16005C01620002080002
VCID: 47C852556FA7469FF32-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0026751413
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323E1381F4A5D337B4C-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0181721439
Coding: 011B062200B90080832008040001030F000000000000000000 0000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0506
Coding: 011F16005E01620002080002
VCID: 46D65F5168AD5F97084-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000438369
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B000EE5D38F82FFF7A-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 120810-0002-075
Coding: 1121A6601000A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D0400FDED9B8CCFE9E-8078
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 E HW: 4G0 035 061
Component: Radio U DAB H60 0099
Revision: AB001007 Serial number: 109G10C7572837
Coding: 010103020100000001
VCID: 1F18EA3597B76E5F6B2-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 H HW: 4G0 035 670 H
Component: H-BNT-EU H49 0526
Revision: -------- Serial number: 190HZ0C7517243
Coding: 050101000003E1EF05808B3E00000003000001000000000000
VCID: 280AF1E9C2F9A9E71A8-807C
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC94028TYE
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LH2000SO
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0506
Coding: 010F14004001620002080002
VCID: 49CC546D79B3B0EFE56-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J27G4IS
Coding: 1080004
VCID: 2616FFD1C4EDBF97284-8072
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0506
End----(Elapsed Time: 02:06, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
