Thread: Audi A4 2.0 TDI - B7 - 2006 Loss of power intermitant
  1. Audi A4 2.0 TDI - B7 - 2006 Loss of power intermitant
    Dec 2008
    Hi all,
    Really hoping somebody can point me in the right direction of where to go next with a problem i have got with my wife's Audi A4 Sline 2.0 TDI 2006 (90k) . She said it has been driving 'really flat' as of late so after taking a run it myself....coincidently the engine management light came on. I used a Autotel reader on the car and got the following code - 01027 Rear Warm Air Fan (V27). After searching on the internet i linked this to the EGR valve and thought this was a good place to start. Today i stripped down the throttle body and EGR and found it to be clogged up as expected, so spent a couple of hours cleaning both until i was really happy with them. After putting back together, i changed the oil, oil filter, air filter, pollen filter. I was then really disappointed to find nothing had changed on taking a run in the car afterwards. Im pretty stuck on where to go next other than buying a replacement EGR valve (seen on ebay for around 50). Could this still be causing the issue even though it was put back spotless?? I checked a couple of the hoses that i could see and all seemed fine.
    Any help or advice would be greatly appreciated.
    Stu
  2. Re: Audi A4 2.0 TDI - B7 - 2006 Loss of power intermitant
    Jan 2009
    Birmingham
    13 Post(s)
    change your egr valve the gears are worn on yours
    EGR Valve Cleaning & Replacement – Audi A4 TDI
  3. Re: Audi A4 2.0 TDI - B7 - 2006 Loss of power intermitant
    Dec 2008
    Quote Originally Posted by arman123 View Post
    Hi thanks for your reply, I removed the EGR again and inspected the plastic gears. Sure enough they were very worn in one area, so bit the bullet and replaced with new EGR. Job done and all good!
    Thanks again
  1. Please Help 2006 Audi A8 D3 3.0tdi 'Sudden Power Loss'
    By meffe in forum A8 - S8 - V8
    Last Post: 18-06-2013, 12:11 AM
  2. AUDI A4 Avant 2006 auto diesel - ECS light showing + loss of power
    By delightful in forum VCDS - Users Locations
    Last Post: 11-03-2013, 02:44 PM
  3. Fault Code 00519 Audi A6 C5 Power Loss intermitant
    By spottedhaggis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-05-2011, 07:22 PM
  4. Please Help intermitant power loss
    By trevor simpson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2011, 11:25 AM
  5. Audi A4 - intermitant loss of power; going into fail safe mode
    By mkirby1981 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2011, 08:42 PM
