Hi all, first post so be gentle
I’ve recently bought a 2014 S Line Plus and I’m considering widening the track and fitting spacers.
I’ve decided to go for 20mm front and 30mm rear per corner and will go for the type that screw to the hub to eliminate the need to change bolts, change locking nut but also for a more robust fitment.
Is there anything wrong with the options I’m considering and are there any material downsides to going the spacer route?
I don’t intent to lower any further than what I get in dynamic although I’ve heard through vagcom I can get the standard setting changed to lower from stock, which is interesting.
Thoughts appreciated.
