Thread: 2012 Mk VI 1.6 tdi Match BMT - Suddenly will not start
  1. Unhappy 2012 Mk VI 1.6 tdi Match BMT - Suddenly will not start
    Nov 2012
    Fareham
    Car is regularly serviced and has just reached 50k miles. Was working fine - with the exception of the STOP/START function which has worked only twice in the last 8 months - until I tried to start it yesterday afternoon. On switching on the ignition, a beeping sound is heard, the steering wheel and brake warning lights come on, the engine starts very briefly, immediately stops and then tries to re-start unsuccessfully. The beeping sound continues throughout and the messages "Button for driver assistance sys. faulty.", "Oil pressure: Engine off! Owner's manual!" and "Error: Brakes. Workshop!" appear in that order until the ignition is switched off when the beeping stops. I thought the problem might be a dead battery in need of replacement (its decline seemingly likely to be the reason why the START/STOP had stopped working) but I had no joy trying to jump start it. I wonder if anyone could suggest an explanation for this sudden failure? Many thanks.
  2. Re: 2012 Mk VI 1.6 tdi Match BMT - Suddenly will not start
    Nov 2012
    Fareham
    It gets worse. I fitted a new battery to see if that would fix the problem - it didn't but fine as the car is booked in to a local VW specialist in 4 day's time and a friend has offered to give me a tow to the garage. So today I thought I would give the car a good clean. All the electrics, save for the radio which was asking for a code which I apparently have to go to the main dealer to have input (I have never had it, despite owning the car from new but I assume this is the norm in the UK) seemed to be working fine so I dropped the windows to clean their seals - and guess what, they won't close. Rain is forecast so I have had to resort to plastic sheets and sticky tape as well as disconnecting the battery to reduce the risk of the alarm going off.
  3. Re: 2012 Mk VI 1.6 tdi Match BMT - Suddenly will not start
    1840 Post(s)
    New battery or not it would seem to be flat!
  1. Please Help 2.0 litre 140 Diesel estate stopped suddenly and won't start.
    By Rogg2 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-01-2017, 11:18 PM
  2. 2012 Match - Bluetooth not Autoconnecting
    By johnsimcox in forum Golf MK6 - 2009 - 2013
    Last Post: 18-05-2013, 01:21 PM
  3. 2012 Polo 1.2 TDI 75 bhp Match (5D) - questions
    By burningoil in forum Polo - Derby - Lupo - Fox
    Last Post: 11-01-2013, 07:02 PM
  4. Touran 1.6S rough cold start & suddenly low MPG
    By Cass IoW in forum Touran - Sharan - Caravelle
    Last Post: 30-01-2010, 08:09 PM
  5. Polo GT suddenly wont start
    By biggles0509 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-12-2006, 10:58 AM
