Thread: MMI control unit
  1. MMI control unit
    Apr 2018
    Ormskirk, United Kingdom
    I have a 2014 A6 Ultra S-Line S-Tronic. The rotary knob in the centre console for controlling the MMI has failed. From the symptoms it seems that it is actually a 3-position switch and one of the three positions has failed. If I rotate the knob the selection on the MMI screen alternates between two options (i.e. it moves up one then down one). Turning the knob slowly I can see that the cursor moves on the first click but stays put on the next click, moves on the next click and so on.
    I can't see any evidence online that this has happened to anyone else. If there is a quick and easy fix that would be good to hear. But I guess the only way to fix this is to replace the MMI control unit in the centre console. It is obviously going to be cheaper if I do this myself with a second hand unit rather than get an Audi dealer to fix it. I have seen someone selling second hand units claiming that they need to be programmed for the vehicle. Is this true? If so, what needs to be done? How difficult is it? Is it something I can do with a laptop and an appropriate cable?
    Thanks for any advice.
  2. Re: MMI control unit
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Have you spilt anything on the mmi? Worth removing and stripping it down so you can clean the contacts with some electrical cleaner. A used unit does not need coding to your car. Even the later versions work with the 1st gen mmi systems
  3. Re: MMI control unit
    Apr 2018
    Quote Originally Posted by morski View Post
    Haven't spilt anything recently! But will take a look at stripping down the existing unit. Thanks for the quick response.
  4. Re: MMI control unit
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi. I have a 65 plate and the knob started to get notchy and stick down Audi at first lubricated it with a light oil, lasted about 9 months then started again. Audi then replaced the whole unit under warenty the first fix was at the direction of Audi as a known issue and resolution. Hav a try spraying WD40 or switch cleaner down the switch shaft, it may help for a while.
  1. Control Unit
    By joannelut in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2010, 10:28 PM
  2. Please Help ABS Control Unit
    By volcom in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-08-2009, 12:37 PM
  3. abs control unit (ecu)
    By gordycaddy in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2008, 07:39 AM
  4. A4 ILM control unit?
    By cosmo2978 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-04-2008, 09:57 AM
  5. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
