Thread: Alternator workshop warning, cause - failing tensioner???
  1. Alternator workshop warning, cause - failing tensioner???
    Apr 2018
    Hamilton Scotland
    Hello,
    The Alternator Workshop warning light came on? It is intermittent, although the battery warning light is staying on. There is a thrumming noise which dims the lights on the dash, I think the belt tensioner is failing, and the belt is slipping causing the voltage to fall. There is movement on the tensioner, which ties in with the noise but I am unsure if this movement is normal. When I put a meter on the battery it is moving between 12 and 14 volts. Don't want to pay for a new alternator if the tensioner is the cause. Is there a way to check? Thank you.
  2. Re: Alternator workshop warning, cause - failing tensioner???
    1841 Post(s)
    On which car?
  3. Re: Alternator workshop warning, cause - failing tensioner???
    Apr 2018
    Hamilton Scotland
    Hi, It's a 2003, vw passat, 1.9tdi, 145k miles.
  1. Please Help Alternator belt tensioner + Alternator clutch pulley - time and money?
    By Cliveski in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2013, 02:25 PM
  2. Alternator Workshop Warning Flashing
    By mikegbingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2010, 02:41 PM
  3. Alternator Workshop
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-08-2010, 10:03 AM
  4. T4 alternator tensioner
    By bennb229 in forum Touran - Sharan - Caravelle
    Last Post: 26-06-2009, 11:24 PM
  5. Please Help Alternator Workshop! Dash warning
    By Robbus in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2009, 04:27 PM
