Thread: Brake warning light
Results 1 to 10 of 12
  1. Brake warning light
    Feb 2013
    Gloucester
    57 Post(s)
    I knew my front pads were low and recently the warning light came on. I booked the car into my local Indy who changed the pads and while they were at it, I had the discs done too. All back together and the warning light remains on. No VCDS fault codes, the brake fluid is at the right level and I checked their work and it’s all ok (warning wire connected).
    They said on the A6s they have recently seen an issue with the with the wiring harness being corroded and failing. I find this odd as the light cane on at the correct time as the wire wire through.
    Anyone know what the issue may be?
    Sent from my iPhone using Tapatalk Pro
  2. Re: Brake warning light
    1840 Post(s)
    It is very easy to route the wire incorrectly and have it cut or worn though by the rotating parts. The pad warning system is not liked to the diagnostics as it is a simple closed circuit checker.
  3. Re: Brake warning light
    Feb 2013
    Gloucester
    57 Post(s)
    I’ll have another check. All looked good to me when I took the wheels off yesterday when putting the summer set back on.
    Just strange it appeared with the genuine low pads but now not disappeared
  4. Re: Brake warning light
    Mar 2014
    Edinburgh
    235 Post(s)
    Did they replace the sensor? Normally once the sensor has been triggered it’s pretty much buggered. Sensors are fairly cheap and some pads comes with them.
  5. Re: Brake warning light
    Feb 2013
    Gloucester
    57 Post(s)
    Yeah it’s a brand new looking sensor. Suppose I could multimeter test it?
  6. Re: Brake warning light
    Mar 2014
    Edinburgh
    235 Post(s)
    Some Audi’s/vw were bad for corrosion in the plugs/terminals. Might need a squirt of wd40 or something to clean it up.
  7. Re: Brake warning light
    Dec 2015
    London
    13 Post(s)
    Quote Originally Posted by M1tchy View Post
    Guessing u ruled out the obvious next? - the rear brakes also have a sensor
  8. Re: Brake warning light
    Aug 2007
    Hook Hampshire
    21 Post(s)
    When the sensor shorts and illuminates the warning light, is it because it is in contact with the disc or is it because the sensor wears as a result of rubbing against the disc and is therefore closed circuit.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  9. Re: Brake warning light
    Feb 2013
    Gloucester
    57 Post(s)
    Yeah it’s not the rears, I had them done 6 months ago. I’ll check it with a multimeter later and see how the contacts look.
  10. Re: Brake warning light
    1840 Post(s)
    Quote Originally Posted by shabazmo View Post
    It is a closed circuit until the sensor wears through and breaks the circuit which is why a broken wire brings the light on.
  1. Red brake warning light flashing and constant abs light
    By lee.p.wood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2014, 06:45 PM
  2. ABS warning light & flashing brake light
    By mrbiondi in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2011, 01:47 PM
  3. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  4. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
