Thread: ESP 2006 golf plus no light on dash and button off lit up
Results 1 to 10 of 13
  1. ESP 2006 golf plus no light on dash and button off lit up
    Apr 2018
    Just got a 2006 golf plus but I’m not sure ESP is working.
    i don’t see a symbol when turning the key.
    The ESP button has off lit up.
    pressing the button doesn’t appear to do anything.
  2. Re: ESP 2006 golf plus no light on dash and button off lit up
    1840 Post(s)
    Failure of the G201 ESP system pressure sensor on the Golf 5 (PQ35 platform) was rife, so much so it became a problem for VAG for a time and there were frost made to try and help deal with the problem, for a time and was extremely expensive to repair and it also became an MOT failure so it is likely that the ESP warning light has been disabled and this will complicate correct repairs. A fault code read with a scan of the ABS system should reveal all, do you have recourse with the seller?
  3. Re: ESP 2006 golf plus no light on dash and button off lit up
    Apr 2018
    Hello, thanks for the reply. I bought it from a used car place so I should be able to take it back and hopefully they’ll fix it.
    How would you disable the esp warning light? It would explain why it does appear when all the other lights on the dash light up.
  4. Re: ESP 2006 golf plus no light on dash and button off lit up
    1840 Post(s)
    Quote Originally Posted by Mattwlkr View Post
    Do you mean "does not" appear?
    You can disable the light in a number of ways but hopefully they have not damaged the panels internals otherwise this will more than double the cost of the repair.
  5. Re: ESP 2006 golf plus no light on dash and button off lit up
    Apr 2018
    Shouldn’t the esp/ car with tracks icon show when you first turn the key?
    All I have is ‘off’ lit up on the esp button.
  6. Re: ESP 2006 golf plus no light on dash and button off lit up
    1840 Post(s)
    Yes the ESP light should come for a second or so with the ABS light and then go out, I just took this pick of the dash in my office managers 2007 Golf Plus 1.9 TDI 90.
  7. Re: ESP 2006 golf plus no light on dash and button off lit up
    Apr 2018
    [QUOTE=Crasher;1084154]Yes the ESP light should come for a second or so with the ABS light and then go out, I just took this pick of the dash in my office managers 2007 Golf Plus 1.9 TDI 90.
    Yeah definitely don’t have that icon, in fact I’m not sure I saw the abs light either...
  8. Re: ESP 2006 golf plus no light on dash and button off lit up
    Apr 2018
    [QUOTE=Mattwlkr;1084155]
    Garage reckons its the button that is not working. I’m not convinced at all, the ESP is supposed to switch back on next time the engine is started isn’t it? Don’t want to have to pay to have a diagnostic scan just to prove my point...
  9. Re: ESP 2006 golf plus no light on dash and button off lit up
    1840 Post(s)
    Each time the ignition is cycled, the ESP override resets. When the ESP is off and the light is on in the switch, this is accompanied by the ESP light on the dash which goes off when you turn the ESP back on. They are either inexperienced, clutching at straws or giving you male bovine excreta... I would lay good money on the fault code stored as being 01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
  10. Re: ESP 2006 golf plus no light on dash and button off lit up
    Apr 2018
    Do independents have the correct diagnostic equipment to find this error? There’s isn’t picking anything up apparently. Don’t want to fork out £85 on a VW diagnostic
  1. emission light come on dash t4 estate 2006
    By stillcool67 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2017, 10:11 PM
  2. "Auto" button and Unknown Dash Light
    By Adambaz in forum Touran - Sharan - Caravelle
    Last Post: 15-06-2016, 07:37 PM
  3. Question Any 2016 Golf 150 EU6 DSG Owners with missing ESP button on Dash ?
    By Brian1970 in forum Golf MK7 - 2013 - 2019
    Last Post: 11-05-2016, 07:36 PM
  4. Mk5 (2006) golf 1.9tdi se flashing glow plug light.
    By Tanks13 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-08-2015, 12:37 PM
  5. Please Help Odometer reset button on dash not working.
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2011, 09:14 PM
esp
