Thread: Noise/groan from Steering at low speed
  1. Noise/groan from Steering at low speed
    Jun 2014
    newport, s wales
    an old complaint from my car has returned. A4 Avant 1.9tdi 130
    When pulling out from kerb at very low speed i can hear and feel a slight groaning noise in the steering system.
    Fluid checks ok.
    Last year i had similar issue , but then it disappeared.
    i want to sell the car in about 4-5 months so i would like to cure it.
    I did check pulley on alternator last year, which appeared to be ok.
    Anyone got some suggestions please?
  2. Re: Noise/groan from Steering at low speed
    Aberdeen
    63 Post(s)
    When did you last change the power steering fluid? Could just be a sign the power steering is on the way out. I had this on one of my cars and changed the fluid which helped a lot but it came back and was like that for a couple of years with no deterioration.
  3. Re: Noise/groan from Steering at low speed
    Apr 2018
    N.Ireland
    9 Post(s)
    I had researched this before and found something relating to a steering wheel/ column retention spring or ring, I had a google but cant find where id seen it for the B6. If you find it let me know because I get the same problem when turning the wheel it feels like there is a jumping of gears and a popping.
  4. Re: Noise/groan from Steering at low speed
    Dec 2011
    East Grinstead
    Are you sure it is steering and not CV joints? Inner CV joints will clunk when pulling away if worn.
  1. Question Noise at slow speed steering
    By Jack Lomas in forum Chat - Anything with wheels
    Last Post: 20-04-2015, 10:24 AM
  2. Steering Groan/Shudder
    By warrenm14 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-06-2011, 02:08 PM
  3. Please Help Noise when steering at low speed
    By eyedoc in forum Golf MK4 - 1999 - 2004
    Last Post: 09-01-2010, 02:14 PM
  4. Question Power steering groan/grinding noise
    By drivergolfmk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-11-2009, 12:22 AM
  5. A4 TDI 1.9 Steering Groan!!
    By bigwheels280 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2008, 05:19 PM
