Thread: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
Results 1 to 10 of 17
  1. Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jan 2017
    norway
    Hello,I have a 2005 Audi A6 3,0 tdi (BMK). I have sometimes special when engine has been hot and then stands for a while some struggling when trying to start again, same as the touareg in the link (Touareg V6 hot engine starting problem - YouTube). And no, its not bad battery.. i also have the sound like sounds like chain rattle specially when starting after stop in 30 minutes and start again. I have changed all 6 injectors, bought them from eBay germany refurbished injectors. Not really big different before and after. No fault codes from VCDS that indicates anything with engine.
    I was reading about camshaft position sensor possible defect could maybe give these symptoms? Anyone who now where the camshaft position sensor is located on BMK engine? Any thoughts if this could solve the problem?
  2. Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Check/change injectors with new or used in good condition. No refurbished. No camshaft sensor involving in this situation.
  3. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jan 2017
    norway
    That is on my mind, but hard to belive when changed all 6 once already...
  4. Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    In this case take the new injectors out and test them on a bosch piezo stand to see if they are good.
    I personally fixed a lot of problems with the change of all the 6 injectors on my 2.7tdi bpp 2005 A6, including the starting at hot engine. Used injectors bought on ebay at 80 euros/piece.
  5. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by L3g10n4rU View Post
    Is there a write up on changing injectors and testing them etc
  6. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    What do you mean about ‘write up’? Do you need advices about changing them by yourself? The machine that tests the injectors already knows all the information to calculate for the injectors and test them with the factory one.
  7. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Nov 2016
    england
    33 Post(s)
    I mean a guide to self testing and removal and replacement
  8. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    The only self testing guide is to test the injectors with a vacuum pump. Open the pipe connection on each injector with the engine stopped and put in some vacuum. If the injector holds vacuum for around a minute, than this is good. If it loses in few seconds it means it is a bad injector leaking at idle.
    To get them out is very easy, just get some keys for opening them and take care not to brake the return plastic like pipe. I can give you the elsawin info if you really want.
  9. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Nov 2016
    england
    33 Post(s)
    That would be great if you can do that I'd really appreciate it thank you
  10. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Aberdeen
    63 Post(s)
    I took mine to a Bosch dealer who tested them and ultrasonically cleaned them. Much better afterwards.
  1. Please Help Camshaft position sensor audi a4 b8 2.0tdi 2011
    By jchauhan123 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2017, 07:39 PM
  2. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  3. Question Camshaft position sensor
    By paul.c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2012, 08:36 PM
  4. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
