Thread: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by Scott K View Post
    I took mine to a Bosch dealer who tested them and ultrasonically cleaned them. Much better afterwards.
    So they were fine but needed a clean? How do you mean dealer? Like a bosch garage? How much did this cost? Thanks
  2. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by L3g10n4rU View Post
    The only self testing guide is to test the injectors with a vacuum pump. Open the pipe connection on each injector with the engine stopped and put in some vacuum. If the injector holds vacuum for around a minute, than this is good. If it loses in few seconds it means it is a bad injector leaking at idle.
    To get them out is very easy, just get some keys for opening them and take care not to brake the return plastic like pipe. I can give you the elsawin info if you really want.
    Any luck with that info mate? Thanks
  3. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Aberdeen
    63 Post(s)
    Yes, there is an auto electric garage which is an authorised Bosch agent. They bench tested them and then cleaned them. This helped with the starting and hesitation issues. Wasn't completely solved but so much improved. They also supplied new o rings for the injectors. It was a while ago but seem to remember it was around £40 per injector.
  4. Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    This is how you check injectors for leaking at idle.
  5. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    This is the info you need for changing the injectors. Sorry for takaing so much time, I had some personal problems. Thanks.
  6. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    It is a simple job, don’t listen to everything that is writen there. Just untight them and pull the injectors by hand, performing left-right turns untill
    You pop them out.
    Pull out the old copper seal with some pliers.
    Change the copper seal, the oring and lubricate it with engine oil.
    Clean the chair of the injector on the engine with a flat screwdriver and a cloth but take care not to brake something.
    If you need more info ask me.
  7. Re: Hot start struggles Audi A6 3.0 tdi (BMK) camshaft position sensor?
    #17
    Nov 2016
    england
    33 Post(s)
    You pop them out.
    Thanks mate that's well appreciated, no worries sorry to hear that and I hope things are going a bit better for you again now, will do
  1. Please Help Camshaft position sensor audi a4 b8 2.0tdi 2011
    By jchauhan123 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2017, 07:39 PM
  2. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  3. Question Camshaft position sensor
    By paul.c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2012, 08:36 PM
  4. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
