Thread: Juddering at 1900-2000 rpm
  1. Juddering at 1900-2000 rpm
    Aug 2012
    Lusseray, France
    Hi to all.
    I have a tdi 130 (AWX) 2004 saloon. Bought in Dec.2017 with 110 000 mls and a good service history. I have a juddering/hesitation in all gears at 1900-2000rpm which corresponds to French speed limits(where I live) ie. 50kph (3rd gear) 70kph (4th gear) and 90kph (5th)particularly pronounced when towing a trailer. Seems to run ok above and below these revs. A lot of white smoke on starting from cold (smell of fuel). Fuel consumption is worse than expected. Little bit of audible whine from turbo. I have put a Warm Up fuel system cleaner through which improved a bit of rough running.
    Just about to make 5000km journey and need to know what is causing this. Glow plugs are original - could these cause such problems? at what intervals should they be changed? Any advice?
    Many thanks Rob
  2. Re: Juddering at 1900-2000 rpm
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    Could be your injector harness. It’s about the right age to be dying by now. People go on about mileage but it’s time that does it. Gets brittle.
    54 Passat Wagon PD175
    99’ Audi S4 Avant 2.7 QTO
  3. Re: Juddering at 1900-2000 rpm
    Aug 2012
    Lusseray, France
    Many thanks MiniMental for advice. If this is the harness is it something that will progressively get worse or suddenly fail? I am not going to have time to sort this before my 5000km journey.
    Rob
  1. A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    By jameswtownsend in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-02-2013, 07:45 PM
  2. passat 1.9 tdi awx misfire at 1900 rpm
    By tidla in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-08-2012, 04:55 PM
  3. 2001 SE TDI 1900 AWX diesel-oil leak
    By Mamohau in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2011, 10:22 AM
  4. TDI whooshing noise at 1900 rpm
    By the_old_diver in forum Touran - Sharan - Caravelle
    Last Post: 23-11-2008, 09:59 PM
  5. Growl at 1900 rpm!
    By SW TDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-11-2008, 01:29 AM
