Saturday,07,April,2018,10:23:35:00001
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ8K8AA027298 License Plate:
Address 01: Engine
Control Module Part Number: 03L 906 022 NP
Component and/or Version: R4 2.0l TDI H20 9978
Software Coding: 12194012232503080000
Work Shop Code: WSC 50664
VCID: 000EB89C9B03024418-8054
Advanced Identification/FAZIT
Identification: BPG-810
Revision: 25H20---
Date: 27.06.09
Manufacturer number: 1334
Test stand number: 0726
Flash Status
Programming Attempts(application): 1/1/1
Monday,02,April,2018,19:28:06:00001
www.Ross-Tech.com
Address 19: CAN Gateway Labels: 8T0-907-468.clb
Control Module Part Number: 8T0 907 468 T HW: 8T0 907 468 K
Component and/or Version: GW-BEM 4CAN-M H09 0101
Software Coding: 00CF07
Work Shop Code: WSC 06335 000 00000
VCID: 52AA42D41DEF40D4FE-8006
3 Faults Found:
01964 - Front Passengers Seat Height Adjustment Switch (E290); Up
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:27:19
Freeze Frame:
Bin. Bits: 10111
Temperature: 3123.2°C
Raw, Form. N/A: 054 000 006
Inj. On Time: 6 ms
Time: 25.40 s
00816 - High Pressure Sensor (G65)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:27:19
Freeze Frame:
Bin. Bits: 10111
Inj. On Time: 6 ms
Time: 25.40 s
01040 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:27:23
Freeze Frame:
Bin. Bits: 10111
Monday,02,April,2018,19:33:41:00001
www.Ross-Tech.com
Address 5F: Information Electr. Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 8T2 035 666 M HW: 8T2 035 666 D
Component and/or Version: H-BN-EU H41 0187
Software Coding: 01010101030681FD01004F1E000000030001
VCID: 45806988CCA1E76C6B-8010
1 Fault Found:
03606 - Control Circuit for Ambient Illumination
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 235762 km
Time Indication: 0
Date: 2018.04.02
Time: 13:03:52
Freeze Frame:
Voltage: 12.40 V
Monday,02,April,2018,19:39:21:00001
www.Ross-Tech.com
Gateway Installation List: 8T0 907 468 T
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0001
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
26-Auto Roof -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Not registered 0001
53-Parking Brake -- Status: Not registered 0001
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0001
Saturday,07,April,2018,10:37:48:00001
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 8K0-907-379-V1.clb
Control Module Part Number: 8K0 907 379 AK HW: 8K0 907 379 AK
Component and/or Version: ESP8 front H04 0070
Software Coding: 160504
VCID: 020AB2949D0F10540E-8056
1 Fault Found:
01486 - Over-Temp Sensor (G189)
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:35:32
Freeze Frame:
Hex Value: 0x0000
Speed: -65.8 km/h
Speed: -0.0 km/h
Speed: 102.9 km/h
Hex Value: 0x00FF
Successful Attempts(application): 1/1/1
Programming Status: 00000000
Flash Date: 17.11.14
Misc.
Hardware number: 03L 906 019 AL
Workshop System Name: J623
ASAM Dataset: EV_EC2M0TDI03L906022NP
ASAM Dataset Revision: A02012
Car Info
Chassis Number: WAUZZZ8K8AA027298
Engine code: CAHA
VCDS Info:
Labels: 03L-906-019-CAG.clb
Readiness: No script available
ROD: ERROR - EV_EC2M0TDI03L906022NP A02012 (AU48)
Saturday,07,April,2018,10:15:28:00001
www.Ross-Tech.com
VCID: 52AA42D40DEF40D4FE-8006
6 Faults Found:
01342 - Engine Control Module 2 (Slave 1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:41:48
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.30 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
01040 - ABS/Transmission Electrical Connection 2
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:41:52
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.30 V
Count: 6
00448 - Haldex Clutch Pump (V181)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:42:47
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.30 V
Count: 6
Bin. Bits: 10011
02064 - Passenger-side Rollover Solenoid Deactivated
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:42:47
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.30 V
Count: 6
Bin. Bits: 10011
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:42:47
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.30 V
Count: 6
Bin. Bits: 10011
01296 - Sensor for Vent Temperature; Center (G191)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:42:47
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.30 V
Count: 6
Bin. Bits: 10011
Saturday,07,April,2018,10:19:04:00001
www.Ross-Tech.com
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:15:34
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.00 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:15:38
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.00 V
Count: 6
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:16:53
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Bin. Bits: 10011
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:16:53
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Bin. Bits: 10011
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:16:53
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Bin. Bits: 10011
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:16:53
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Bin. Bits: 10011
Saturday,07,April,2018,10:38:02:00001
www.Ross-Tech.com
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:35:32
Freeze Frame:
Hex Value: 0x0000
Speed: -65.8 km/h
Speed: -0.0 km/h
Speed: 102.9 km/h
Hex Value: 0x00FF
Saturday,07,April,2018,10:46:16:00001
www.Ross-Tech.com
Address 5F: Information Electr. Labels: 4E0-035-6XX-5F.CLB
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:45:17
Freeze Frame:
Voltage: 12.20 V
www.Ross-Tech.com
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:27:19
Freeze Frame:
Bin. Bits: 10111
Inj. On Time: 6 ms
Time: 25.40 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:27:19
Freeze Frame:
Bin. Bits: 10111
Inj. On Time: 6 ms
Time: 25.40 s
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 26
Mileage: 235812 km
Time Indication: 0
Date: 2018.04.02
Time: 19:27:23
Freeze Frame:
Bin. Bits: 10111
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 235762 km
Time Indication: 0
Date: 2018.04.02
Time: 13:03:52
Freeze Frame:
Voltage: 12.40 V
www.Ross-Tech.com
www.Ross-Tech.com
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 36
Mileage: 235990 km
Time Indication: 0
Date: 2018.04.07
Time: 10:35:32
Freeze Frame:
Hex Value: 0x0000
Speed: -65.8 km/h
Speed: -0.0 km/h
Speed: 102.9 km/h
Hex Value: 0x00FF
