Thread: Multiple questions about my 1.9tdi
Results 1 to 10 of 17
  1. Multiple questions about my 1.9tdi
    Apr 2018
    Norway
    Hi!
    I am about to sell my golf TDi.
    but I have some issues. For about four or five months ago the motorlamp came on. A friend of mine ran VCDS and found several fault codes. One of them is at my biggest concern which comes to issues I am not able to fix. Believe me I’ve tried a lot of things thats listed on the web.
    273’ km
    The fault is:
    Address 01: Engine Labels: 03G-906-016-BKC.clb
    Part No SW: 03G 906 016 B HW: 028 101 147 8
    Component: R4 1,9L EDC 0000SG 5645
    Revision: 12345678 Serial number: VWZ7Z0C8392138
    Coding: 0000071
    Shop #: WSC 01286 386 08256
    VCID: 224BA092FD81395583-8076
    1 Fault Found:
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 000 - Signal too High
    Freeze Frame:
    RPM: 882 /min
    Torque: 64.0 Nm
    Speed: 0.0 km/h
    Load: 2.7 %
    Voltage: 13.98 V
    Bin. Bits: 11000100
    Temperature: 72.9°C
    Temperature: 63.0°C
    Readiness: 0 0 1 1 1
    I have tried to change the G62 sensor twice. I have followed the cables to check for burns or issues with them. My motor lamp comes on on startup, with fault message «Emissions workshop» Airbag lamp comes on, with message «airbag fault». ESP lamp comes on after excactly 10 min of engine running which leaves the esp not working (but it works inside the 10 min). Temperature in the dash goes up and down. The radiator fan (big) starts running with only the ignition on(cold motor). This concerns me. I believe there is several threads about this, but I am new at this forum so I dont know how to find it hope anyone Can help me PS. I have the hole list of fault codes from VCDS.
  2. Re: Multiple questions about my 1.9tdi
    18 Post(s)
    450 Post(s)
    There is more going on here than you have posted, you need to get a FULL scan of the car done so we can see what is going on in the other controllers. The G62 sensor, do you have the part number of the sensors you have fitted?
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: Multiple questions about my 1.9tdi
    Apr 2018
    Norway
    Thnx for quick reply.
    This is the complete first scan before deleting faults without replacement of sensor.
    Saturday,10,February,2018,12:09:58:20168
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.8.1.0 (x64)
    Data version: 20171130 DS276.6
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W012222 License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: WVWZZZ1KZ4W012222 Mileage: 270290km-167950miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: Malfunction 0010
    Coding: 0000071
    VCID: 224BA092FD813956A7-8076
    2 Faults Found:
    17911 - Load Signal from Alternator Term. DF
    P1503 - 000 - Implausible Signal
    Freeze Frame:
    RPM: 1806 /min
    Torque: 40.0 Nm
    Speed: 15.0 km/h
    Load: 15.3 %
    Voltage: 14.29 V
    Bin. Bits: 11000000
    Load: 60.0 %
    (no units): 1.0
    P0118 - 000 - Signal too High - Intermittent
    Freeze Frame:
    RPM: 1008 /min
    Torque: 94.0 Nm
    Speed: 0.0 km/h
    Load: 8.2 %
    Voltage: 14.21 V
    Bin. Bits: 11000100
    Temperature: 3.6°C
    Temperature: 7.2°C
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0021122
    Shop #: WSC 01279 785 00200
    VCID: 3A7B78F2751151969F-806E
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1K0 907 044 L
    Component: ClimatronicPQ35 061 0201
    Shop #: WSC 00000 000 00000
    VCID: 306F5ADAA36D9BC621-8064
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    000 - -
    Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
    Component: Bordnetz-SG 1.0 H29 0701
    Revision: 00029000 Serial number: 00000000208003
    Coding: 898B8F0600041800001400001400000000
    Shop #: WSC 12345 123 12345
    VCID: 387F62FA4B1D438669-806C
    Subsystem 1 - Part No: 1K1 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer VW350 011 0301
    Coding: 00065493
    Shop #: WSC 12345
    2 Faults Found:
    00988 - Lamp for Brake Light; Right (M10)
    01064 - Terminal 58d; Interior Dimming
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 A HW: 1K0 909 605 A
    Component: 06 AIRBAG VW8 021 0500
    Revision: 03021000 Serial number: 0033FD02RERI
    Coding: 0012342
    Shop #: WSC 01268 785 00200
    VCID: 2A5B48B285B1E116EF-807E
    Subsystem 1 - Serial number: 6332MSME6F3C5300
    Subsystem 2 - Serial number: 6342MSME363C2100
    Subsystem 3 - Serial number: 6351HSME66063400
    Subsystem 4 - Serial number: 6361HSME47033600
    2 Faults Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
    010 - Open or Short to Plus - Intermittent - MIL ON
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 009 0030
    Coding: 0000012
    No fault code found.
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 860 F
    Component: KOMBIINSTRUMENT VDD 1220
    Coding: 0005101
    Shop #: WSC 80093 222 69422
    VCID: 2B554DB68A4BF81E14-807E
    Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 C HW: 1K0 907 951
    Component: Gateway H08 0080
    Revision: 08 Serial number: 21001038242982
    Coding: 3D3F0B40070002
    VCID: 275DB18696A3DC7EF0-8072
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 1220
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0102
    Coding: 0000052
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V1.clb
    Part No: 1K1 909 144 E
    Component: EPS_ZFLS Kl.2 1202
    VCID: 2D5143AEB45FF62E0A-8078
    Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 C
    Component: KSG 0201
    Coding: 00E802087F2D8404084F0100
    Shop #: WSC 00790 218 57246
    1 Fault Found:
    00893 - Switch for Trunk Handle (E234)
    007 - Short to Ground - Intermittent
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Component: Tuersteuergeraet 08 1927
    Coding: 0000052
    VCID: 31695FDEA86792CE2E-8064
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 C
    Component: Tuersteuergeraet 05 0108
    Coding: 0000016
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
    Part No: 1K0 959 704 C
    Coding: 0000016
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
    Component: PTC-Element 0404
    Revision: 00600000 Serial number:
    2 Faults Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    01299 - Diagnostic Interface for Data Bus (J533)
    End-------------------------(Elapsed Time: 02:00)--------------------------
  4. Re: Multiple questions about my 1.9tdi
    Apr 2018
    Norway
    Quote Originally Posted by Smrendal View Post
    Thnx for quick reply :-)
    This is the complete second scan with vagcom (VCDS)
    VCDS Version: 18.1.0.2 (x64)
    Data version: 20180122 DS285.1
    www.Ross-Tech.com
    00-Steering Angle Sensor -- Status: INTERFACE NOT COMPATIBLE
    15-Airbags -- Status: OK 0000
    Coding: 0000071
    1 Fault Found:
    Freeze Frame:
    RPM: 882 /min
    Torque: 64.0 Nm
    Speed: 0.0 km/h
    Load: 2.7 %
    Voltage: 13.98 V
    Bin. Bits: 11000100
    Temperature: 72.9°C
    Temperature: 63.0°C
    Coding: 0021122
    VCID: 3A7B78F275115195BB-806E
    VCID: 306F5ADAA36D9BC505-8064
    VCID: 387F62FA4B1D43854D-806C
    Coding: 00065493
    Shop #: WSC 12345
    Coding: 0012342
    VCID: 2A5B48B285B1E115CB-807E
    Coding: 0000012
    Coding: 0005101
    VCID: 2B554DB68A4BF81D30-807E
    VCID: 275DB18696A3DC7DD4-8072
    Coding: 0000052
    VCID: 2D5143AEB45FF62D2E-8078
    Component: KSG 0201
    Coding: 0000052
    VCID: 31695FDEA86792CD0A-8064
    Address 56: Radio
    Cannot be reached
    Coding: 0000016
    Coding: 0000016
    1 Fault Found:
    014 - Defective
    End-------------------------(Elapsed Time: 01:56)--------------------------
    partnunber for sensors are
    06A 919 501 and 06A 919 501A
  5. Re: Multiple questions about my 1.9tdi
    18 Post(s)
    450 Post(s)
    What is the engine code now? What does the HVAC say the outside temperature is?
  6. Re: Multiple questions about my 1.9tdi
    Apr 2018
    Norway
    If you mean the fault code, it is the same. Outsidetemp is correct in comparison to the weather temp outside. If I got you right?
  7. Re: Multiple questions about my 1.9tdi
    18 Post(s)
    450 Post(s)
    Does the fan come on a few seconds after turning on the ignition or only when the engine is running and does it sound like it is running at full whack or at a lesser speed?
  8. Re: Multiple questions about my 1.9tdi
    Apr 2018
    Norway
    IT comes on after 20 seconds or so. Winds up at full speed after a few seconds and then speeds down at idle then it winds up again at full speed. I have tried to change the sensor on the down right side of the radiator. Meassured voltage to aprox 5V in the contact. The contact which holds the sensor in the motor block has 0V if I meassure between the to pins. But if I meassure between the red/grey and to earth somewhere I Get aprox 5V there also. So i Wonder if there could be something wrong with the earth connection somewhere.
  9. Re: Multiple questions about my 1.9tdi
    18 Post(s)
    450 Post(s)
    It is a digitally controlled system so measuring voltages can throw you off as it is a 5v system and the fans computer inside the large fan needs to know what is going on, if the controller can see the ignition is on but it cannot see the engine temperature the controller assumes the engine is overheating and goes into full speed.
  10. Re: Multiple questions about my 1.9tdi
    Apr 2018
    Norway
    Okay. Do you have any soloution regarding the issues of my request?
  1. Question 1.9TDI Head Gasket Replacement Questions
    By nial in forum Touran - Sharan - Caravelle
    Last Post: 27-03-2018, 04:30 PM
  2. Audi A4 05 1.9tdi Questions
    By pbren91 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-03-2014, 02:38 PM
  3. Question My 1999 1.9TDi 110bhp model... A few questions...
    By mboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2011, 10:23 PM
  4. A4 (B6) 1.9TDI Buying Advice & Questions
    By Agar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-06-2010, 08:34 PM
  5. 1.9TDi Timing Belt Questions.....
    By Iggy in forum Chat - Anything with wheels
    Last Post: 08-08-2007, 11:15 PM
