Thread: Correct Headlight Units
Results 1 to 9 of 9
  1. Correct Headlight Units
    May 2015
    Kirmington, North Lincolnshire
    I've waited long enough, it is time to replace the headlight units - lenses are shot.
    Reading about the aftermarket offerings I think original Hella's are going to be the best choice, I can't work out the correct part numbers.
    Old units have 155923 00 Li written on them, can find very little about them online, with different parts numbers quoted by the motor factors for replacements.
    Anyone know the current part numbers for the headlight units?
    H7/H7 halogen.
    A6 2003 1.9tdi Sport Avant
    2003 Audi A6 Avant 1.9 tdi Sport
  2. Re: Correct Headlight Units
    Aug 2017
    West Midlands UK
    11 Post(s)
    Quote Originally Posted by fishybusiness View Post
    H7/H7 halogen.
    OEM reference numbers: 4B0941004BJ, 4B0941004BK, AU335AXACR, FHL736R, AD0334903, AD50DR8280, 471440241, AUA6202R, LWC544, LWC544, 20-B0070-05-2B, AU923RE, AU451AR, AD0334903, 20B007052B
    I purchased a drivers side OEM for my Quattro SE for £75, now gone up to £93, both were badly UV burned but I managed to recover the N/S with a kit.
    The number in bold was the original part number from Audi, took me a bit of nagging to get the P/N over the phone to my reg number, not sure if your model is the same.
    PM me if you want the eBay seller and item number (they have both sides) as I'm not sure if I can link to it here.
    2003 A6 C5 2.5 TDI Quattro Avant (180bhp)
  3. Re: Correct Headlight Units
    May 2012
    Everywhere
    308 Post(s)
    If the uv coating has oxidised , sand and polish .
  4. Re: Correct Headlight Units
    May 2015
    Cheers for the info - the part number is definitely correct - H7/H7 bulbs. Many of them are H1/H7 which is not correct for this car.
    I'm going to hang on and try and find Hella units, am a bit iffy about the TYC, Prasco's etc.
    Re polishing, yep I've done them last year, seemed to work just about ok, they have gone dull again. Can't see myself polishing them every year tbh.
  5. Re: Correct Headlight Units
    May 2012
    Everywhere
    308 Post(s)
    If they dulled off again you didn't fully remove the UV coat , use 600 first .
    My 2003 Hella is still clear after polishing 4 years ago .
  6. Re: Correct Headlight Units
    May 2015
    Did you renew the UV coating after sanding?
  7. Re: Correct Headlight Units
    May 2012
    Everywhere
    308 Post(s)
    No .
    Got the same issue with some mains powered outside globe lights , will replace with new glass versions .
  8. Re: Correct Headlight Units
    May 2015
    Maybe Audi should sell glass lenses!
    I've resisted a refurb again as the headlights have always been on the dim side.
    Recently found GE Ultra 130 bulbs, and I'm wondering if a refurb and new bulbs will sort them out. Will save stacks of cash.
  9. Re: Correct Headlight Units
    May 2012
    Everywhere
    308 Post(s)
    Ring Xenon 150 .
  1. Please Help Changing factory headlight units for LEDs and transformers -Ive no fitting instructions.
    By Lockstock in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-11-2016, 11:06 PM
  2. two ami units with an mmi 2g
    By tmg in forum In Car Entertainment
    Last Post: 17-09-2013, 01:47 PM
  3. Oem units ..... New to me ..... Need help please
    By prittR6R32 in forum In Car Entertainment
    Last Post: 26-08-2010, 06:31 PM
  4. Question A4 More modern Headlight units '97 SE?
    By Molbus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2009, 09:59 PM
  5. new headlight units
    By stuartclark in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-04-2008, 09:02 PM
