Thread: Rear caliper changed now brake pedal has travel
  1. Rear caliper changed now brake pedal has travel
    Jan 2006
    Hi Guys,
    I have just changed the rear brake calliper on my car. I bled the calliper and after changing it but now the brake pedal has a lot more travel before the brakes start to bite. Do you I need to bleed all the callipers or just that one? I clamped the flexi hose and placed a bung in the end of the hose and to be honest only a very slight amount of fluid came out.
  2. Re: Rear caliper changed now brake pedal has travel
    Jun 2016
    Glasgow
    Give that hub another good bleed first.
  3. Re: Rear caliper changed now brake pedal has travel
    Mar 2018
    GB
    19 Post(s)
    Is the handbrake adjusted up on that side? A trapped air bubble can be a pain or the pads aren't bedding into the disc properly.
    Sent from my SM-G900F using Tapatalk
  4. Re: Rear caliper changed now brake pedal has travel
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Check for leaks around the flexible caliper hose connection and bleed nipple. A proper pressure bleed bleed is much better than merely bleeding thro' the bleed nipple and pumping the brake pedal . A pressure kit is sold by Halfords = its quite cheap and very effective. Modern hoses can be damaged by clamping.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Rear caliper changed now brake pedal has travel
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Those calipers can be tricky to bleed effectively, consider taking the caliper off the pins, blocking the piston travel with a block of wood and bleeding it while twisting it in various positions to work the air out. You'll need help to do this and a pressure bleeder is a must, imo.
  1. A6 1999 TDi 1.9 Brake pedal travel, normal with ABS?
    By Alas in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-07-2012, 09:46 AM
  2. Brake pedal travel
    By Northsea in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-09-2011, 09:01 PM
  3. Question Excessive Brake Pedal Travel
    By jaym15try in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 27-08-2010, 01:28 PM
  4. Golf mark 4 excessive brake pedal travel
    By MCHAUDRY in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2009, 09:44 PM
  5. Brake pedal travel
    By aid in forum Golf MK5 - 2004 - 2009
    Last Post: 14-02-2008, 12:25 AM
