Thread: P2015 again
  1. P2015 again
    Apr 2010
    uk
    Since December I have been running around with an engine warning light on and the scan at the time indicated p2015 which I am led to believe is the intake manifold flap position. After trawling around the web I found the aluminium fix kit for around 20 quid but i never got around to buying it but this morning I stumbled on this video which shows the removal of the unit and a quick clean and a couple of squirts of wd40, unit refitted and hey presto no warning light.
    Just wondering what your thoughts are on it.
    https://www.youtube.com/watch?v=DJ7ojoNpQ5I
  2. Re: P2015 again
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Worth a try but the small bolt on 'fix' is specifically to stop over extension of the lever mechanism and therefore eliminates out of range readings. A clean is a free attempt so why not.
  3. Re: P2015 again
    Apr 2010
    uk
    Thanks for reply DMitch. Since posting this topic I have discovered that that it has a plastic inlet manifold and a as I am picking up a b7 tomorrow I have decided put the car up for grabs but I will probably end up giving it away to my son. All this diy stuff is a bit beyond me nowadays.
  1. Question Intake Manifold Flap Position Fault P2015
    By Justme2012 in forum VCDS - Help Requests
    Last Post: 30-03-2018, 12:37 AM
  2. Solved p2015 error
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-04-2017, 05:32 PM
  3. p2015 - intake flap position motor
    By climbachia in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-08-2015, 10:49 PM
  4. Fault code P2015
    By Big Bird in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-03-2014, 10:30 PM
  5. A4 tdi p2015 fault code
    By b13jus in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-03-2014, 07:05 PM
