Thread: VW Golf Regen info
  1. VW Golf Regen info
    Oct 2017
    IRELAND
    What way does this work guys?
    Does the car go in to limp mode,does it fire lights up on the dash??
  2. Re: VW Golf Regen info
    Jan 2018
    Sussex
    55 Post(s)
    Car goes in limp mode if there is some sort of fault with it.
    Also it lights up the dash if there is fault.
    DPF Regen happens with increased idle (About 1000 RPM), but it also increases if its cold and you demand heat in cabin,
    or simply if engine needs to heat up.
    Often after regens your cooling fan may keep going after engine is shut down, to cool engine bay.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  3. Re: VW Golf Regen info
    nottinghamshire
    Mine does it mainly after refuelling
    The rpm increases. It won’t turn off automatically at lights etc. The radiators fan will be on high speed. And you may smell a burning smell. Very important not to switch it off during regen. Can take upto 10mins
  1. info about my golf
    By Anze in forum Golf MK4 - 1999 - 2004
    Last Post: 08-03-2015, 08:34 PM
  2. More Info On The New Golf Mkvi!!!
    By knt in forum Golf MK6 - 2009 - 2013
    Last Post: 15-09-2008, 05:06 PM
  3. info wanted mk2 golf
    By gtiman in forum Golf MK2 - 1984 - 1992
    Last Post: 29-07-2008, 01:17 PM
  4. Some help and info required on my golf 1.6
    By mfosbrook in forum Golf MK4 - 1999 - 2004
    Last Post: 11-01-2008, 09:08 PM
  5. tdi golf's mk3 and mk4 info
    By johnathan in forum Golf MK4 - 1999 - 2004
    Last Post: 10-09-2007, 11:34 AM
