Thread: Polo 9n track control arm bushes
  1. Polo 9n track control arm bushes
    Jan 2015
    Brighton england
    Hi All
    My daughters Polo 9n AZQ needs new bushes in the wishbone arms and VW don't sell them separately, it is a whole arm and yes they want an arm and a leg to pay for it. I was wondering if you can get replacement bushes for the front of the arm and if so where to get them from and is there a procedure for fitting them. I do have a 20 ton press, but will I need anything else to get them to fit in straight.
    Thanks in advance.
  2. Re: Polo 9n track control arm bushes
    Feb 2004
    Yorkshire
    46 Post(s)
    May be worth trying some of the large motor factors such as Euro Car Parts, Andrew Page or one of you local motor factors, I think you will find they will do them cheaper
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of the Institute Of Advanced Motorists
    Member of BMW Car Club GB
    Ways to support the website
  3. Re: Polo 9n track control arm bushes
    Jan 2015
    Brighton england
    Thanks for your reply I have decided to go down the Powerflex route after a bit of research as the bushes are far easier to install, will last longer than the standard bushes and can do both side for less than half the cost it would be to fit OEM parts.
  4. Re: Polo 9n track control arm bushes
    Feb 2004
    Yorkshire
    46 Post(s)
    Good choice
  5. Re: Polo 9n track control arm bushes
    Dec 2014
    Bedford
    42 Post(s)
    I find it is easier to leave the console housing in place and just remove the lower track control arms then remove the bushes . You can buy a tool for fitting them on Ebay for about £15. Be careful though about 10 % of the time the track control 18 mm bolt can snap and then your in the brown stuff. Remember to lubricate the inside of the bush that the track control fits into or a week later you end up with a very annoying squeaking noise.
  6. Re: Polo 9n track control arm bushes
    Jan 2015
    Brighton england
    flapperjack76 thanks for your reply, but it is actually the front bush in the wishbone that needs replacing not the console bush, have done many of those and have the tool you mention, very useful. As for the 18mm bolt i have had one completely seized and ended up having to cut it out with a small angle grinder. I then removed the console and drilled out the old bolt on a pillar drill and then run a correct sized tap through it. ( took a while and would have been easier to get another console from the breakers, but I hate to be beaton!)
    As above I have replaced the front bush with a powerflex, which hopefully will put up with the rough tracks my daughter goes on with her horses and they are much easier than pushing in a new Febi bush, which if they don't go in straight, you then can't get the 18mm bolt to line up and you are back to square one.
    I also put the bolt back in with a good application of gold grease to stop it from seizing.
  1. Question Audi A4 b7 track control arm who makes them
    By michaelhare in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-11-2016, 02:35 PM
  2. Question Track Rod End Bushes
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2013, 07:34 PM
  3. Front track control arm's - which make?
    By Columbo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-11-2011, 07:20 PM
  4. How To Useful Advice - Track Control Arms - Touran
    By Witty in forum Touran - Sharan - Caravelle
    Last Post: 06-11-2009, 07:58 PM
  5. Question Lower Front Track Control Arm
    By VAG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-11-2008, 01:38 AM
