Thread: Leaking Pan Sunroof
Results 1 to 10 of 18
  1. Leaking Pan Sunroof
    Apr 2018
    Yorkshire
    Hoping to get some advice if poss!
    i have a 2014 A6 Avant, and 2 weeks ago I discovered the drivers footwell swimming with water one morning. After doing some research we thought it was the plenum chamber, so my husband cleared it out (there was some crap and debris in there)
    anyway, come Friday and itís wet in the footwell again. Decided to take it to a ĎAudi specialistí on Saturday. He discovers that the water is coming in from the front of the pan roof as the headlining is soaking, itís basically running down the front door pillar and in to the footwell. He tested with some water and it soaked away as it should do, so he fitted a bung to a drain hole in the hopes that would fix it. It didnít. Got in the car the following day and the passenger side footwell is damp, as is the headlining, and then this morning after the heavy rain overnight, the drivers footwell & headlining is saturated. Car currently has a tarpaulin over it til I can get it to a garage.
    my question is, what could it be? I have the option of taking it to a VAG garage this week, or direct to Audi, but Iím guessing Iíll have to pay for Audi to even look at it? Any ideas of cost?! How long is a piece of string kind of question isnít it?!
  2. Re: Leaking Pan Sunroof
    Dec 2009
    Amesbury, Wiltshire
    15 Post(s)
    From another recent post:
    Quote Originally Posted by neebsta View Post
    The seals for these roofs are terrible, mine is crumbling in places and the car is out of warranty.
    the part itself is £64 plus VAT - then my dealer claimed it's a massive 6 hour job and labour alone would be over £660 excluding VAT
    Has anyone changed a seal? Is it as big a job as Audi make out?
  3. Re: Leaking Pan Sunroof
    May 2014
    Darlington
    51 Post(s)
    Have you ever had the pan roof serviced?
    I've got no idea why they would bug the drain holes, that is just going to cause problems.. If anything they should be cleared out.
    There is more than one drain on the roof, so I would invest in getting it fully serviced and checked over.
  4. Re: Leaking Pan Sunroof
    Apr 2018
    Yorkshire
    Christ, I certainly don’t have that sort of money at the moment! Do you have a link to that thread please?
  5. Re: Leaking Pan Sunroof
    Apr 2018
    Yorkshire
    Quote Originally Posted by B5NUT View Post
    No, not specifically the sunroof. Unless it’s checked during the normal service, which I’m certain it isn’t. I’m not convinced the guy actually knew what he was fully doing, so I’m torn between taking it to Audi or a VAG garage here.
  6. Re: Leaking Pan Sunroof
    Dec 2009
    Amesbury, Wiltshire
    15 Post(s)
    Quote Originally Posted by Mental Minnie View Post
    Christ, I certainly donít have that sort of money at the moment! Do you have a link to that thread please?
    Iím not sure how to post a link Iím afraid, but if you look for, I think, ďPanoramic sunroof seal replacementĒ from about 3 weeks ago you should find it.
    I think I might request a sunroof service at my next service...
  7. Re: Leaking Pan Sunroof
    Apr 2018
    Yorkshire
    Quote Originally Posted by robes401 View Post
    I’m not sure how to post a link I’m afraid, but if you look for, I think, “Panoramic sunroof seal replacement” from about 3 weeks ago you should find it.
    I found it thanks!
    I wasn’t offered a sunroof service by Audi last year when I had the car serviced at the dealership?!
  8. Re: Leaking Pan Sunroof
    Dec 2009
    Amesbury, Wiltshire
    15 Post(s)
    I found it thanks!
    I wasnít offered a sunroof service by Audi last year when I had the car serviced at the dealership?!
    Iíve had the car since new, 3.5 years, and never been offered a sunroof service, but on my service record have Ďsliding roofí noted at first service 18k miles (but didnít pay extra for it). My online service schedule states ďRoof insert panorama sliding roof: Check, clean and greaseĒ every 40k miles or 2 years.
  9. Re: Leaking Pan Sunroof
    Apr 2018
    Yorkshire
    So an update.
    Took the car to a VAG specialist whom took the headlining apart today. Basically the cassette (I think thatís what itís called) that the pan sunroof sits in is made up of 2 plastic U shapes, joined together. On BOTH sides the joints have split apart. The garage think that itís started to leak and with the cold weather the water has frozen, expanded and split the frame. Itís going to cost over £800 alone for the cassette from Audi, then labour.
    Iím tempted to now take the car to Audi, let them diagnose the same fault and then kick up a fuss. Surely itís not fit for purpose?! The car is under 4 years old.
  10. Re: Leaking Pan Sunroof
    Apr 2011
    basingstoke,england
    11 Post(s)
    So an update.
    If the sunroof service is recorded as being carried out when the car was 2 years old, I think it would be a good idea to try and get some goodwill against the cost, without the service you would have zero chance.
    2016 A6 Avant 2.0 tdi Quattro Black Edition
    2013 A6 Avant 2.0 tdi Black Edition ​gone
    2010 A6 Avant 2.0 TDI Le Mans. gone.
  1. Water leaking down edge of rear seat. Sunroof?
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2010, 08:06 AM
  2. leaking matrix leaking.
    By gold7 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-03-2009, 08:56 AM
  3. Please Help sunroof going up on its own
    By solorider in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-03-2009, 11:41 AM
  4. Leaking Sunroof
    By Dee-GTI in forum Golf MK2 - 1984 - 1992
    Last Post: 26-05-2008, 01:19 PM
  5. mk4 leaking sunroof
    By rasper05 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-02-2007, 07:10 PM
