Thread: Low battery charge: battery will charge while driving
  1. Low battery charge: battery will charge while driving
    Feb 2018
    Oxford
    Hello guys I would appreciate your help in the problem I have if anyone knows what’s that
    Today i went to start the car and low battery charge: battery will charge while driving came up, so I called AA and they charged the battery checked if something drained the battery and how many amps it uses after the car is locked. It looked like the problem was in the phone charger and they advised me to unplug the charger before I switch off the car.
    The thing is after driving the car 4 hours at least the fault still comes on and in the mmi it says 0% battery even if I have battery.
    Any suggestions what’s that come be ?
  2. Re: Low battery charge: battery will charge while driving
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    If your battery was dead, you need to charge it with a rectifier. How old is the battery? Is the generator working well? Any errors found with vcds?
  3. Re: Low battery charge: battery will charge while driving
    Feb 2018
    Oxford
    Yes the battery was flat and AA jump started it and have a look for leaks. The battery is 3 years old the alternator charging it as normal should
  4. Re: Low battery charge: battery will charge while driving
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Do you have vcds? Enter channel 61 battery and take a look at the readings. What is the battery state of charge(soc) and the actual current given by the generator?
  1. Question Can't seem to charge that Battery.
    By beulahgig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-01-2016, 04:04 PM
  2. Replies: 0
    Last Post: 23-08-2015, 06:34 PM
  3. Battery state of charge.
    By pcr in forum Golf MK7 - 2013 - 2019
    Last Post: 09-03-2014, 04:07 PM
  4. BATTERY LIGHT ON 2.7TDi Q 2005 - NO BATTERY CHARGE
    By shairaz1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 02:05 AM
  5. car battery losing charge
    By shunter in forum Golf MK4 - 1999 - 2004
    Last Post: 12-09-2007, 04:58 PM
