Thread: Assistance for new member
  1. Assistance for new member
    Mar 2018
    Wales
    First off I would like to say hello, I look after several cars in the family, namely a 2014 VW beetle 1.2 tsi, a 2002 Audi A2 1.4 TDI and a 2014 E250 cdi I am after some advice if possible regarding the beetle. I need to replace a vacuum sensor Part no 0 261 230 170. What I don't know is how to remove the faulty sensor without breaking it. It appears to be fastened using using some form of plastic clip
  2. Re: Assistance for new member
    Apr 2015
    Bedford
    6 Post(s)
    The only way I can see it is to squeeze the pins and lift gently on 1 side then repeat on the other, is going to be pig to get that off specially when sensor is sitting on O-ring, failing that can you see if you could cut the pins off, drill little wholes and use 6-8mm bolt with nut to re secure the sensor if you brake them pins? Looking at that pic is silly design as plastic gets brittle over time and lot easier to brake. Good luck anyway
  3. Re: Assistance for new member
    Mar 2018
    Wales
    Many thanks, yes that is what I thought about squeezing. Im just afraid to break. VW must have a tool for this surely.
  4. Re: Assistance for new member
    Apr 2015
    Bedford
    6 Post(s)
    Quote Originally Posted by the-nuke View Post
    Hmm not sure about VW tools, had a little idea not sure if will work, try to find small socket that will force the pins to squeeze as you pushing on them from top and from bottom use plastic trim remover tool, if not wait a bit someone else might know other ways, that is he problem if the pins are brittle will be very easy to break them.
  1. Assistance needed!!!
    By Mac27614 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-09-2015, 07:20 PM
  2. Thanks for assistance
    By stevepd in forum VCDS - Help Requests
    Last Post: 23-10-2013, 08:30 PM
  3. Vcds assistance please
    By Jack Lomas in forum VCDS - Help Requests
    Last Post: 18-03-2013, 02:33 PM
  4. VW Assistance
    By simonsheil in forum Passat CC
    Last Post: 25-05-2011, 11:12 PM
  5. Please Help Hi new member needing assistance...
    By kyasle in forum New Member Introductions
    Last Post: 13-03-2010, 12:45 AM
