Thread: Oil pressure warning stop! immediately 1.9tdi
Results 1 to 10 of 13
  1. Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    Hello, I'm new to this forum so please go easy on me!
    Tonight on the way home from a 30/40 mile trip about 100m from my house my car started saying it had oil pressure issues and to stop immediately I managed to get the car home when I turned off the car the fans were going at full speed but the temp gauge was at 50 any advice?
    Other info on the car
    Not sure of last service
    Done around 84k
    1.9tdi
  2. Re: Oil pressure warning stop! immediately 1.9tdi
    May 2012
    Somerset
    268 Post(s)
    Engine code ?
  3. Re: Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    Quote Originally Posted by Gazwould View Post
    Engine code ?
    Not sure of the engine code ATM any ideas what could be causing this?
    Sent from my Pixel 2 XL using Tapatalk
  4. Re: Oil pressure warning stop! immediately 1.9tdi
    Nov 2010
    Shetland & S.Tyneside
    103 Post(s)
    At the risk of stating the obvious; have you checked the oil level? Post the three letter engine code, presuming this is an old pd engine, or four letters if common rail.
  5. Re: Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    Quote Originally Posted by Rob69 View Post
    Just checked the oil it's fine but my engine code is BXE
  6. Re: Oil pressure warning stop! immediately 1.9tdi
    Nov 2010
    103 Post(s)
    Have you noticed any strange or knocking type noises from the engine, have you tried starting it from cold and if so do you still have the oil light coming on?
  7. Re: Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    I haven't tried starting it up yet just incase but even though the car has sat for around 12 hours the car fans still kick in on full wack and there was no strange noises when I parked up it was running fine
  8. Re: Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    Quote Originally Posted by Callum53 View Post
    Also the warning buzzer sounds and the handbrake light flashing when you put the key in the ignition
  9. Re: Oil pressure warning stop! immediately 1.9tdi
    Nov 2010
    103 Post(s)
    Check your batttery voltage is ok should be around 12.5 V or slightly more with engine off, it sounds more like electrical gremlins than mechanical problems, start the engine briefly and check voltage while running, should be 14.5V. If voltage is ok you'll need a vcds scan to start diagnosing the problem.
  10. Re: Oil pressure warning stop! immediately 1.9tdi
    May 2012
    Somerset
    268 Post(s)
    BXE isn't the best engine code as the upper conrod bearings like to wear through and spot weld to the crank...
  1. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  2. Please Help Stop engine/oil pressure warning light comes on
    By GnasheRRR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-10-2011, 11:05 AM
  3. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  4. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
  5. STOP ! Low Oil Pressure Warning
    By Tnarg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 11:33 AM
